In wall cables for EU 230V circuit
Could you please describe more about your experience with solidcore vs stranded cables?
I had both types :
1- Stranded cable 10mm2 (8AWG)
2- Solidcore 16mm2 (6AWG , not single core , it includes 8 x 2mm2 solidcore wire)
I did not have single core wire but If you have any experience please share?
Thank you
I agree you furutech and most other hifi companies are not as good as oyaide.
I agree you schuko is not very good for high current audio applications.
I do not use shielded hifi cables between ac panel and my audio system. I use regular cheap non-shielded cable .
Die besten Solid-Core-Kabel, die ich kenne, sind solche von Vovox (Swiss professional Company), bei Strom (Model Excelsus) und bei RCA/XLR-Kabeln.
Beste Oyaide-Power-Plugs: The Models C079, better than C046 and C037. I have all of them and compared then with the same AC-Cable Supra Silver 40th Anniversary.
Besides the Oyaide 046, 037, and 079, I have also used the 004, F1, M1, various Furutech plugs, and many receptacles from those brands. I’m glad the 079 works for you. It’s a good option, but it can be considered the best when matched with a regular bright silver due to its roll-off character imposed by the gold plating. With top silver or copper cables 046 or 004 is great but Frutech FI-11 is better than those. Choice of receptacle also plays a major role.
Luca, I installed Neotech 4003 mains from my consumer unit in a UK 230v system. It's rated 27A and very flexible.
For two longer runs (for AV and modem) I used the standard Belden 19364, which is a bit stiffer. I use some Supra Lo-Rad for power leads and it is even stiffer, but built for durability.
The 4003 is silver plated OFC with a drain cable, there are UP-OCC versions.
I got mine from HiFi Collective. You can get samples, may be easier to get from Audiophonics in France.
I need to run a power cable from a UK consumer unit to a new location in my listening room. I will go for a 12m run of Neotech 4003 inside trunking and behind a fabric wall. Will that all work ok? It’s it a single socket and will then use a shunyata typhon for my amp and cd player
I guess it is all about trying what sounds best for your set-up (and ears). I tried all three of them (37, 47 and 79) , and for me the 046 was best. Anyhow, great power plugs.
Reactions: mtemur
