Have always wanted to hear those. Did a review of some Analysis Audio ribbons that is as close as I've gotten to that type of design.
I am in Sacramento CA.
I've got three 48-inch carver ribbons. They were for a speaker project that was never completed. What should I do with them? What are they worth?
Ribbon: Since those Little Ds, I’ve been a fan of ribbon drivers. Went a long time with domes and cones before returning to ribbon tweeters and mids in my VMPS RM40s, and the Sunfire CRM2s I use for surrounds.
They are worth quite a bit! The Carver ribbons were used in the large Genesis loudspeakers prior to 1996. These are $20,000 loudspeakers, so if someone blows a ribbon, they will pay quite a bit for a replacement as they are no longer available.
I think both they myth and fact are true . It is true that these drivers have large surface area and can cool off that way. But it is also true that they don't really like to get hot as that can deform the substrate and or delaminate it. The company we were working with really sweat this as they had drivers destroyed this way and they were always looking for ways to make them better.Some myths and facts:
Myth #1: "True ribbons can’t take high input power."
Fact: If constructed properly, they can take hundreds of Watts of input power, more so than any other technology within the same frequency range. One of the reasons is the membrane itself. It acts as an efficient double-sided heat sink.
Welcome to the forum. Very nice first post .
Tom
Valid points but it remains that any conductor can be destroyed by heat and in the case of ribbon it can be rather low... In ribbon the main problem remains that of the substrate usually a plastic (Mylar, Kapton, etc) .. when submitted to high currents the substate, the film itself can deform or be damaged permanently. True the large area allows cooling of the wires but the sibsrte itself as a (rather) low melting temperature, compared to that the metal reach under sustained high current... but indeed I have been surprised to see how much power some ribbons and quasi-ribbons can take at times... (Apogee and Magnepan)
Amir talk to Bo Bengtsson at Transmission Audio. He responds quickly and will take the time to answer your questions. IIRC Bo believe's the only ribbon drivers that will be destroyed by large quantities of clean & undistorted power, are ribbons that's are not properly constructed from the beginning. As Bo states "The best ribbon would be a transformerless, purely resistive, (coil-less and carrier-less), pure metal film ribbon of open dipole-type, suspended at its ends only, wide enough to give a good coupling down to the lower frequencies. This is exactly what the Transmission Audio Ultra Propulsion© technology is all about."
The problem Amir is most of what passes as being a "ribbon" driver today is actually a form of Planar Magnetic Transducer. Perhaps the company you were working with should contact Bo? Transmisson Audio offeres a variety of services: http://www.transmissionaudio.com/servicesandportfolio.html as well as being able to provide the company you were working for an incredible variety of ribbon speakers to choose from, should they only be looking for one or a few pairs! With that I should probably end this by stating I am not affiliated with Transmission Audio in any way and say Good-bye...
Frantz while I agree wholeheartedly that any conductor ---**even a ribbon}--- can be destroyed by heat, but I disagree that in the case of ribbon it can be rather low. The problem once again is too many "supposed" ribbons aren't ribbons at all! If the "ribbon" has a substrate of plastic (Mylar, Kapton, etc) I say that is actually a form of Planar Magnetic Transducer and not a ribbon! I agree with Bo Bengtsson at Transmission Audio i.e., a ribbon is a transformerless, purely resistive, (coil-less and carrier-less), pure metal film ---{no substrate}--- that's suspended at its ends only!
Of course you're free to have a completely different interpretation of what a ribbon truly is...
Been into ribbons since i've first heard the Emit K on my Kappa 8s and then 9As.No other type of tweeter can come close (to my ears-you can have all the beryllium and diamond dust of the world onto your domes-i don't care).Then the sickness progressed when i had my first encounters with Maggies and big Infinities.Soon i understood that the placing of a dipole speaker is a pain in the ...,so i turned to speakers that have tamed the rear
sound wave.I now own a fine speaker that has a cult following in central Europe which i have modded with double panar mids and ribbons.View attachment 217
This way i could lower the mid cross point to the TL loaded woofer at 300Hz and gain more body/presence all the way up.
My next speaker will be completely diy with arrays for planar mids (LFT-10s)and ribbons (also LFT new neodymium long tweeters),plus double symmetrical TL woofers...I will have the time of my life making it!
