Bias produces prejudice. Prejudice produces a false consistency. Look at Stereophiles' recommended components lists. I just don't see that type of consistency there.
Greg we will probably disagree, and that's ok, but I don't think it is bias that produces a false consistency in blind testing. I'm not at all sure there is a false consistency in blind testing. That conclusion is a result of the very high number of negatives resulting from blind testing, and while there are a lot of crappy tests being done and I'd never argue that there are no false results, I would expect nothing less than a lot of true negatives. Why? Because we don't blind test Revel Salons vs. Klipschorns or vinyl vs digital. These differences are easy to spot. What we test is the stuff that, at best, is on the edge of audibility. When we test for differentiation, we test the differences that are very subtle, the things that are particularly hard to tell apart. We often find, and it should be no surprise, that when sighted knowledge is taken away, those subtleties are very hard to detect, and that they may vanish entirely. That's not shocking to anyone but the guy who thought he heard a difference before he closed his eyes. On the other hand, blind listening isn't just for testing audible differences. It can also be used to test preference without the bias of sight, and the folks at Harman do this often. Do they get a lot of false negatives? No. They get true positives. Their listeners hear differences between things that clearly sound different, and choose their preferences among them.
Tim
