Hello there!
I have bought a digital drum kit, but cause of it being digital, the expandibility is next to non existent, unless of buying another drum kit and place it next to each other.
But then you have the problem of having 2 drum modules, which then need to be connected to 1 headphone, and also having the ability to let the drum modules producing sound simultaneously and that the headphone lets me hear the sounds from both modules.
Ofcourse i have looked online to see if there are jack cables that are like having 2x male jacks, and then being converted to 1 female jack, in which i plug my headphone, however...
The cables that i have found are mentioning, that the 2x male jacks, are outputs, and that the female jack is input.
So, is it this simple that they also work the other way around?
Cause i saw online that it is possible to have 1 audio devices and then using 2 headphones on it, with 1 male jack and 2 females.
So, there seems to be cables that have 2 males, and 1 female, but should this work for me?
And if not, would there be another method to achieve my goal?
Thank you very much in advance!
Greetings from Martijn from the Netherlands.
