You ought to take a look at what a Typhon is and does because you obviously don't know....or you are confusing it with a Triton
And there is no surge protection in either a Typhon or Triton.
g'day Stehno,
Speculation that removing the Typhon from the circuit is likely to increase the musicality or be a fix for thin bass balance is probably about 180 degrees away from reality. I also thought that the culprit here had already been traced to an under-spec transformer for the equitech tho could be wrong.
In regards to the concern for loss of sq with whole of house surge suppression or even the single Carling electromagnetic hydraulic breaker in a Triton is fairly much not a significant issue given the $100,000s of wide band width high performance gear in a state of art setup like Madfloyd's and besides it'd be crazy irresponsible bordering on pure insanity to run that much gear unprotected.
I could see how a less expensive setup you could possibly make a case for running the risk and avoid the attendant issues with cheaper noise suppression gear like any impeding of the current flow. Anything that detracts from musicality is going to be potentially even more of an issue in a system without a preamp as they often potentially lack a certain dynamic drive and so with your Oppo 103 running direct into your W4S class d amps any loss of musicality rather than loss of detail might be more of a critical issue especially given the D class breeds traditional tendency to some dryness and an overly analytical presentation ( tho apparently not as much of an issue with the later generation D class amps).
g'day Stehno,
Seriously Stehno?? A blast of paranoid outrage is just not cool or necessary. My only interest in this thread is actually in Madfloyd's system. The comment to you was primarily clearing up a total misconception that you had about the effect of a Shunyata Typhon in a system but that is always the danger with your regular assumptions on components that you have zero experience with.
As far as your gear specifically you brought them up and I was clarifying that they had little or no context with Ian's system that has a degree of resolution way beyond normal and that opens up a whole different set of issues about fine-tuning beyond the norm based on my experience with some more resolving setups.
Beyond that I made no comment on the quality of your gear good, bad or otherwise but only recognizing a characteristic analytical quality that pairing with no preamp stage would make and I have heard both of these components at times as well as a range of other Sabre based dacs and a few d class amps.
On me making any insinuation at all or dismissing your gear based on their price you are just plain wrong and I happily and regularly enjoy music on a range of systems from $5k to $500k and also have gear from modest to more expensive in my own systems and enjoy both good music and good value above all. Just chill out Stehno and let's just get back to Madfloyd's system which is actually the point and something we can all learn much from.
I believe you, Tao.
Tell me. Is there any part of MacFloyd's system that isn't sacrosanct when speculating why he experienc(ed) a light bass and overall thin sound in regards to his electrical concerns?
Stehno, could you clarify what you mean by this post? I have the impression from this thread that MadFloyd has more or less solved the issues initially raised in the OP.
Hi, Peter. I had not read anywhere where Mac alluded to "problem solved" so I assumed the thread just died of natural causes. I even asked MacFloyd if his problem was resolved but his only response was the amps were now on their own dedicated circuits.
I was just reiterating that MacFloyd at some point suspected he had issues with his electrical that was potentially inducing an abnormally thin presentation with weak bass. In my attempt to speculate via some internet troubleshooting, those unfamiliar with the problems of doubling up or daisy-chaining differing AC filtering / line conditioning methodologies most always will worsen the presentation, not improve it. Regardless of the quality of either.
For example. Let's say you have a $50k amp whose performance you deem is above reproach. That amp mtg'er discovered during his R&D that when he solders a $5 AC filter to the back of his $50k IEC inlet, he noticed that it sounds slightly more musical and gives his product a slight musical edge over the competition. And say, just as many-to-most, that mtg'er never engaged in any other type of AC filtering / line conditioning, so to his ears and to the many-to-most's ears that $5 AC filter he soldered to the back of his IEC inlet proves beneficial.
You've purchased and have now owned and enjoyed the performance of that $50k amp one year. Along comes a new $25k superior state-of-the-art line conditioner that everybody rants and raves about. You have no experience with AC filtering / line conditioning products but decide to see what all the hub-bub is about so you audition this new line conditioner over the weekend by plugging it into your $50k amp whose performance you so enjoyed the past year. Upon first listen, the music presentation just took a bit of a nose dive. Not much but clearly not as detailed nor as musical as before installing the highly rated line conditioner.
Now you probably know nothing about the cheap $5 AC filter inside the $50k amp, nor do you have any experience with line conditioning of any kind. But you consider yourself an astute audiophile with a fairly well-trained ear.
By default, guess which product is to blame for the demise in sound quality? Not the amplifier but the superior line conditioner and the line conditioner is now deemed by you to be an inferior product, perhaps you make the leap to thinking it’s snake oil. Maybe you even conclude since the industry deemed this to be the best line conditioner available and since the best line conditioner made your system sound worse, perhaps all line conditioners are snake oil and hype and anybody owning a line conditioner is being deceived.
All of this very real potential can and does occur not because of the superior $50k amp nor because of the superior $25k line conditioner. But because of the cheap $5 AC filter soldered behind the amp's IEC inlet.
What does any of this have to do with answering your question?
Simply that no matter how much somebody desires to put a product up on a pedestal and pretend it’s about reproach, regardless of its standing in the industry, it still remains a viable detriment in certain configurations.
And I’m not saying anything negative (or positive) about the Shunyata in the least. But apparently it’s not just a power strip or power distributor as some thought it to be since according to the Shunyata website the Typhon and/or Triton employs some forms of noise suppression and perhaps some form of surge protection. Two variables that at least two current owners were unaware of. Hence, two additional variables that can cause performance collisions with other products. Collision that apparently some were unaware of until now.
That was part of what my suggestion for testing was about. To perform a process of elimination to check for compatibility vs collision in a specific configuration that obviously includes the Equi-Tech, maybe even some $5 AC filters here or there, and maybe even some other unknowns that any one of MacFloyd’s mfg’ers may be employing.
But apparently to some, the Shunyata is sacrosanct and therefore needs to be removed from any electrical troubleshooting equation altogether and I should repent for even daring such a suggestion.
This is nothing more (or less) than pure dogmatism.
Stehno, see post 58 on page 6.
The sound is much better with dedicated circuits and no transformers on the amps.
