I'd wager that the analog output stages and their current capability, etc. are at the root of these differences.
Lee
Of course, and if they are as clearly different as caesar says, one the other or both of them are pretty grossly inaccurate.
Tim
Lee
i have a number of 15ips 1/4" master dubs with quite outstanding percussion and drums. in my system these demonstrate what is possible in reproduced percussion and drums. you then step down into vinyl, DSD, hirez PCM and redbook and you can hear the effect of the format on the level of realism present.
BTW if you accept that the CD laser reading mechanism can have a contribution to sound you are in the witchcraft domain.
Although I understand the importance of reproducing drums and percussion, can you correlate your findings on this type of recording with general sound quality? It seems to me most people attach too much importance to this type of reproduction, mostly because it is something you can easily compare with the real and it is challenging, but it is not a fully revelatory test.
I believe there is general agreement in our hobby that fast transients and lack of dynamics are major limiting factors in creating the live music illusion in the home. Reproducing a drum with a live impact is a major challenge to audio systems, and I believe that's why Wilson has been so successful as a speaker company. But before the speaker even gets the signal, electronics are in the way...
I recently compared a couple of very hign end cd players in the same system - the Boulder and the dCS Scarlatti. The dCS sounded more natural in the highs, but Boulder had a very live bass that gave the music an excellent foundation. Boulder guys would be the first to say that they are not adding or subtracting anything from the signal deliberately, but are just passing it along. And so would dCS!
Yet others like Naim add nice pacing and rhythm to the music to make it more engaging, but lack the lively, visceral percussiveness that Boulder has. Why don't more companies engineer that "realness" in the foundation? Is this an engineering limitation or an audiophile taste limitation?
Hi caesar
Can I ask why it is that your first port of call as it were is that there is a profound difference between (supposedly) hi end quality electronics?
It sounds fishy to me to be completely honest. IF true, then I wonder even more about the guys who spend this sort of money. Just get a neutral player and add quality EQ to it. Cheaper, better job, and you can take it away when you wish, and change it to boot.
Tell us what the conditions were. Right now I would be using any energy in investigating that area first. A long way to go before we get to the amazing sonic differences part.
Terry, I know you are an audio skeptic,.
but I had a non-audiophile drummer in the room with me. This guy knows what live music sounds like! He much preferred the Boulder due to its more "real", lively bass. .
So either dCS has not figured out the engineering behind this type of sound or they purposefully suppressed it to make their $80K stack sound "analog".
Just sayin that well executed, quality tone controls (bass and treble) will get you there easier and every time.
Tom
Tom
Tom,
Changing out things like caps, etc. can do much more to the sound than just tone controls. They can have a dramatic affect on imaging, soundstage (amount of width and depth), how natural the sound, timber, amount of detail, dynamics, etc.
Rich
I think you missed what I was saying, tone controls would never increase detail,articulation,clarity,and frequency response. In my experience they just try to boost either end of the spectrum,which has always been frowned upon by most audiophiles.
As I understand it, capacitors, and most tone controls, are passive. They are not capable of increasing or boosting anything.
Tim
http://www.octave-electronics.com/Parts/cap/bg_tech.shtml
Capacitors have a real effect on distortion levels in the signal path. Less distortion,less noise produces measurable improvement in the audio signal. While the "wire with gain" concept may never be acheived,overall lower distortion will yield a more faithful audio signal output,and in fact better sound.
Lower distortion will effect eveything your ear hears across the board.
In their most basic form, tone control circuits attenuate the high or low frequencies of the signal. This is called treble or bass "cut". The simplest tone control circuits are passive circuits which utilize only resistors and capacitors or inductors. They rely on the property of capacitive reactance or inductive reactance to inhibit or enhance an AC signal, in a frequency-dependent manner.
It all depends on the design circuit and it's intended outcome,for better or worse. I would not favor a attenuation circuit being used in my signal path,just an unnecessary passive device to possibly add distortion.
http://en.wikipedia.org/wiki/Tone_control_circuit
I get all of that; it supports what I said. Capacitors, like simple tone controls, are passive and don't add anything (except, possibly, distortion). Therefore, capacitors, just like passive tone controls,
They can't do it. They don't have it in them. The most they can do is stay out of the way. Semantics, perhaps, but I consider these semantics important. The noise, distortion and loss introduced by a capacitor can be measured and a good bit of very expensive wishful thinking can be avoided if we pay attention to the the very real difference between believing that such parts can expand a soundstage or increase system dynamics and understanding that they cannot do any such thing, they can only be more or less transparent than another capacitor.
Tim
Those Duelund caps are very expensive. I was going to put them in my head amp but ultimately did away with the coupling caps
