Lampizator DSD DAC
Thanks for the post. I have read about this. But I did not have time to try it as yet.
My way for now us on an iMac with audivana
It's the best I have going with my B7 so far.
Regarding PCM and DSD. For me I am do happy with the PCM as is
And have not tried up sampling.
Al
Yeah, on Mac you are kind of stuck. Sorry, didn't even think of that. And yes, PCM certainly doesn't need a conversion. Conversion to DSD makes it sound different. Not necessarily better.
But for people who use the DSD only lampizator, and who use Windows, give ASIO proxy a shot.
May I suggest you use ASIO-proxy instead of using Jriver's internal converter? ASIO proxy is part of the Foobar pool of software, but can be used with Jriver or any software that uses ASIO. In my opinion, its conversion of PCM to DSD is superior to Jriver. It can also upsample or downsample DSD.
Are there some instructions somewhere that illustrate how to accomplish this?
Download ASIO proxy, latest version from Soundforge from this link. ( I am not sure if you need to have foobar installed first, you may or may not.)
http://sourceforge.net/projects/sacddecoder/files/foo_dsd_asio/
Install ASIO proxy on computer.
In Jriver, under AUDIO DEVICES, you will have an option for
foo_dsd_asio. Choose this as your driver.
Then, click on DEVICE SETTINGS. Then OPEN DRIVER CONTROL PANEL.
Under this, select your ACTUAL asio driver, if your device has one. If not, you will need ASIO4ALL.
Select DoP or Native for the type of DSD transmission protocol your DAC needs. There are also options for ExD and DCS(***See note at end of post****)
Be sure and DE-SELECT DoP as transmission format anywhere else, EXCEPT for the Asio Proxy options.
Then you can play with various types of SDM modulation, data rates etc. I tend to stay away from SDM A and C, as I can still hear some low level quantization noise in the playback! If I use 32fp (floating point) mode, though, the noise goes away, making me wonder if it is an issue with my computer not having enough horsepower to do the computations in integer mode. SDM B is VERY syrupy and lush, almost synthetic. I personally find SDM D to be the best overall. But experiment for yourself! It is fun!
****** Note that if your DAC supports and you choose Asio Native mode, asio native does NOT support 'illegal' data rates with DSD, So you are stuck with 2.8mhz, 5.6mhz, etc. Which means you will NOT be able to use any PCM rates that are a multiple of 48khz.
44.1, 88.2, 176.4, 352.8 work perfectly. 48,96,192,384 don't. To use those rates, you must choose DoP as your transmission format. But if you choose DoP, note you may lose the ability to upsample to DSD256, depending on your DAC.
It may be a little more trouble, but the results are worth it, in my opinion.
Very cool my only issue is on a vacation in a another state. Keep me posted and I will post when I get back.
Al
Two questions for people familiar with the Lampi DACs ...
(1) If I feed a Lampi via the spdif outputs of an Aurender W20, does the Lampi automatically switch sample rates for DSD files? My playlists commingle PCM and dsf files. (I would not be feed the Lampi via the built in USB input.)
(2) How "noisy" are the units, particularly the L7? My speakers are over 105db efficient, so even minor residual background noise can be problematic in my system.
Thanks!
The lampi distributor in the UK is a horn fan so all his speakers are over 100 db and they are fine.
Thanks!
Yes, the Lampi can autosense between DSD rates. Not sure about autoswitching between DSD and PCM, as I have a DSD only Dac. AL has a B7 and says it dead quiet, when answering the same question for another pal who has 105db speakers.
Thanks!
Hi Bruce,
Yes, I can confirm- as the owner of Avantgardes Duo Omega which have 107 db efficiency - that lampi dsd dac is very quiet.
Nevertheless, when plugged in one can hear the small residual noise of the unit itself, at least when you approach the dac very close. That noise is not amplified and does not go to speakers.
Imo, the most important element with efficient speakers responsable for the level of the noise floor is the amp and not a converter.
And one more thing Bruce- why you do not connect your W 20 via usb which is outstanding?
Rgds
Mariusz
Mariusz, thanks.
Connecting the W20 via USB would be fine, and provide for greater sample rate coverage.
Heard the new Big 7 yesterday. Awesome, and now on this you can tube roll both the 2A3s and the 45s. 2A3 appear to have more bottom end but 45s are more open. Tough to choose between them but good thing is one can have both tubes and decide over time which ones suit which type of music
Yup I have that DAC now - the same one bonzo heard.
Been playing with EML 45s, Shuguang and Electro Harmonic 2A3s today.
I had the two box L7 a while ago too. Here's a quick and not so good pic. This thing is bigger in the flesh than it looks in the photo.
Justin - welcome to this forum! People here will surely love your system, so do post it under the Member's Gallery
Just joined for the Lampy thread(s) so a system post is unlikely here. So many forums, so little time:)
I will be bringing the Lampi DSD DAC to RMAF this year. Will be connected to a MacBook playing DSD files via Audirvana and then going into a Cavalli Liquid Gold Headphone amp. The best combo I feel available today.
RM. 8000
RM. 8000
Bruce, which set of headphones will you be using for the demo?
Thanks
Neville
Never mind about mk ll. They have two slash marks in front of the name on the web site. I thought that was indicating a new model.
