Been wondering about the Weiss and how well it would stack up. Thanks for your report, highstream. Does that warmth have you thinking of making the switch?
At the Pacific Audio Fest (Seattle) a couple of weekends ago, Lukasz explained the improvements to me, with a change in the nature of the circuit regulation being key, voltage to current regulation for the first time, as I fuzzily recall. He said it offers a big SQ improvement over earlier engines, but warned that its volume is 1-2 dB less gain than previous versions (he asked if I like to listen loud). Also no tubes included unless ordered separately. He said this upgrade supersedes the Golden Atlantic, which is no longer. I just sent mine off to Poland today for it and the JL upgrade, as well as a port repair. Will report back.Golden Atlantic TRP 3 is beyond the Horizon , any idea what it will inherit?
When you say „softer“ is this a matter of gain or sound impression? With gain, the TRP has enough headroom according to my listening experience.Forgot to mention that Lukasz warned that the upgraded model is a little softer than previous ones. I think he said a dB or two (he asked if I like to listen loud). I added that to post above. Also no tubes included, unless ordered separately.
Thank you for the hint to the GraphitAudio footers! I‘m using a dedicated platform from Akustik Manufaktur called „The Rock“ which improved the SQ of the TRP IMO with the standard footers, will look for the GraphitAudio ones.Anyone removed the footers from their TRP? I’ve assumed it was just a matter of popping the cover and a screwdriver, but never looked closely. It’s come up in considering Lukasz’s new graphite footers (currently use EVP’s). They’re tall and added to the tall Staycore senders that come with is asking for trouble, let alone adding considerably to the dac’s height.
Hello, I've just come across this thread and your question. Graphite Audio accessories are made of a special polymer that contain a proper amount of graphite. So they are not pure graphite. Graphite is one of many ingredients.After quite a bit of experimentation with different brands and options, I am quite happy with all of my various aftermarket footers, but I am looking forward to some comparisons to these IC-35 footers from other options from Stillpoints, Symposium Acoustics, etc.
Is just the base graphite? The website references a polymer.
You can use GZ37 and secondly SR Orange slow blow 3.15AProbably a silly question, however can anyone tell me whether a GZ37 will work in the TRP? Having settled on the GEC KT66's with the Psvane ACME A274B several years ago I'm about to try some different output valves again - Philips EL50's in the first instance - so will be looking for a compatible rectifier. I just happen to have a "spare" Mullard GZ37 so wondered if it was worth trying but wouldn't want to damage the DAC. I've looked at the manual but that wasn't terribly helpful.
Thanks in advance for your assistance
David Whistance
