In case anyone else was also curious, I found the answer to this by the RTFM method...When using the volume control for a component connected to the analog inputs of the Lampi, does that signal go through the tube stage first or is it just routed directly through the volume resistor ladder?
I am very interested in the indirect heated triode tubes. Especially in relation to the F2a tube. I get your comment on the F2a tube. I appreciate the effort you and Designfx put into these IDHT. Is it possible to give an suggestion for the most open/airy and transparent sounding IDHT you have tried. Furthermore, I need a bit of info about the gain of these tubes. Is it similar to F2a? I have no active pre-amp. I need gain....Well, @GroovySauce , THAT'S amazing looking. Looking at the rest of your sytem, it reminds me of a friend's out in the South Bay area. I imagine it sounds super sweet.
I offer up a more pedestrian follow up that the Mullard CV6 is another knockout - sort of typically Mullard being more reserved than it's KenRad US counterpart, but far from wooly. Very inviting and smoothly detailed. A Sophia 274b v1 give them all the air they need - but nothing like the STR, I'm pretty sure!
These odd little alien two capped triodes are really a treat having all the sonic garden of wonders the 6j5's offer up with more meat on the bone. The soundscape they offer feels very realistic - something the Siemens F2a and Tesla EL51's lacked for me. Those two were/are very exciting to listen to and offer a whole 'nother world. I found their soundscape to be like wandering around in a Maxfield Parrish painting - otherworldly and exciting for sure, but also more of an augmented reality. Could be just me wanting to curl up in my grandfather's sweater with my dog to find a calming refuge, though.
The Tungsol VT94D metal base would be the most transparent, open and airy I've tried. Brimar L63 (ST type) is right behind. I've not heard the straight glass GEC, but it has that rep and is available through Langrex. @Designsfx has more experience w/Raytheon - I have a pair of their 6j5g (ST type) on the way that have good cred and happy to report back. ALL of these don't require adapters, which is an added benefit to my mind.I am very interested in the indirect heated triode tubes. Especially in relation to the F2a tube. I get your comment on the F2a tube. I appreciate the effort you and Designfx put into these IDHT. Is it possible to give an suggestion for the most open/airy and transparent sounding IDHT you have tried. Furthermore, I need a bit of info about the gain of these tubes. Is it similar to F2a? I have no active pre-amp. I need gain....
Not sure but here’s the data sheet if that helps-Anyone know the output impedance of TRP2 w/ F2a output tubes (if the output tubes matter)?
Unfortunately, that is not helpful to me.Not sure but here’s the data sheet if that helps-
How does the Mullard CV6 compare to the National Union 7193? Your description of the Mullard suggests it's similar in sonics to the NU.Well, @GroovySauce , THAT'S amazing looking. Looking at the rest of your sytem, it reminds me of a friend's out in the South Bay area. I imagine it sounds super sweet.
Tungsol VT94D nowhere to find. L63 tubes are relatively expensive. I will try maybe later. But... I bought GEC CV6 tubes for decent money. Would you be so kind to provide me the link on where to buy the adapter. Thanks.The Tungsol VT94D metal base would be the most transparent, open and airy I've tried. Brimar L63 (ST type) is right behind. I've not heard the straight glass GEC, but it has that rep and is available through Langrex. @Designsfx has more experience w/Raytheon - I have a pair of their 6j5g (ST type) on the way that have good cred and happy to report back. ALL of these don't require adapters, which is an added benefit to my mind.
That said, I prefer the 7193/CV6....and they definitely need adapters. And so it goes!
My goodness... All the best of luck to you. Hopefully you are back on track soon.Well-
My lampi just went up in smoke. Don't know what happened, but I just put in a Tele RGN1064 with adapter for a listen and turned around for a few minutes while things warmed up. Smoke was pouring out of the lampi and the bottom far right middle super hot. Looks like that's right under one of the boards....I really don't know. It's heartbreaking, though. Waiting to hear from Lampizator NA and/or the homeland in Poland. In the meantime, I don't know what to say about adapters and tubes other than once they have resistors in them, it might be a little dicey? Until I know what happened, that's about it. Sigh.
For completeness sake, there was also a pair of Kenrad 7193 w/adapters in place. I'd used all the adapters and the Kenrads with a Valvo G1064 without issue.Well-
Oh no! I’m sorry to hear this news. Were you using the same adapter with both the Tele and Valvo?Well-
@Blake @Designsfx yes, in speaking with Rob at Lampizator NA he thinks it’s the transformer with the rectifier at fault. I imagine the adapter was the problem as well. It worked fine previously the Valvo, so it’s hard to point my finger directly at that. Not sure how the tube itself would do that without a faulty adapter, though. The pinout seems pretty specific for that type of tube so it’s hard to imagine a mistake identity. The adapter was from Xuling labs and the tube from a seller I’ve not had problems with the past from Germany.
So sorry to hear about your bad fortuneWell-
