Hahahahhah….OK…Stop making me spend money!
Do you remember what tube complement was used in the H-DAC at Axpona?What lampi has given you guys is the most adaptive
digital to date and all SS dacs should be worried
while digital is not analog the H dac I heard was non discerning to me at axpona. I’ve never felt or heard a direct compare
like this Before
and the axpona room I felt had good vinyl to me.
ThanksDefinitely KT170s and a TAK 274B. I don’t remember the drivers.
I have those ready as well...i need to visit a doctor...specialist...for head...How about the Siemens F2a?
That's a relief to know....then I'll just continue...would love to dig out some interesting Russian NOS pentode which could fit the purpose. Idea is to combine 5c3s recti with Melz and this pentode...so if you know for any whisper it plsThere is no cure.
can you go to a doctor that convinces you to sell all those tubes that you are hoarding for cheapI have those ready as well...i need to visit a doctor...specialist...for head...
aren't 6p3s-e equivalent to 5881/6l6?That's a relief to know....then I'll just continue...would love to dig out some interesting Russian NOS pentode which could fit the purpose. Idea is to combine 5c3s recti with Melz and this pentode...so if you know for any whisper it pls
6sn7Definitely KT170s and a TAK 274B. I don’t remember the drivers.
Wow==bizarre tube. That looks like drug paraphernalia.Yup they are...might try those as apparently there is nothing else...would be cool to try these...View attachment 93002View attachment 93003View attachment 93004
Doubtful. Way too clean inside. But with some modification and the right adapters....Wow==bizarre tube. That looks like drug paraphernalia.
Everybody sees what they would like to see...Wow==bizarre tube. That looks like drug paraphernalia.
Those Teslas look killer!
What rectifier and which triodes are you using. I find the Thomson CSA 5687 to sound best in my system. The Kt170 plus the Tak274B created by far the best dynamicsGuys for all using small signal double triodes i could reccomend to try those things…does not harm but can help as I do believe it helps cooling the bulb itself quite significantly as the fins get extremely hot…
