My first impression of my Pacific did not match the enthusiasm shared in this forum. Once I added the Lucas Audio LDMS, it just took it to a totally different sonic level. So in my case, the Server was more important than the DAC, and, I saved $20k.But all Taiko owners would say that with their respective dacs. That's why they bought the Taiko. Why else would you buy an expensive server if it did not further develop your sound (assuming sonic rationale)
I'm glad you like the RK 5u4gKR RK 5U4G Recti arrived 2 days ago.
Still running in but initial impressions very, very favorable. My TJ 300bs have never sounded better. Mid bass detail seems to just jump - very ”tubey“ sounding if that makes sense. View attachment 82389View attachment 82391
Based on my noise testing on unused analog input that I have posted earlier-quietest so far. Results are attached for 5 different rectifiers I have tested. Maybe there is something to the thicker glass, higher vacuum, etc.
I would rather say "everything matters"My first impression of my Pacific did not match the enthusiasm shared in this forum. Once I added the Lucas Audio LDMS, it just took it to a totally different sonic level. So in my case, the Server was more important than the DAC, and, I saved $20k.
You got only one pair mate? Oh come on, don't disappoint me now.I have ordered some Hytron brown base VT-62. See link. Will post my impressions but they will take a while to arrive from the US.
These may well work in some Lampis, but I can't be sure you will get the best out of them. Try the 300B setting. The easy way to find out is to raise the tube (get some life extenders if you can't raise it enough) and put a voltmeter across the two thick pins (UX-4 base tubes). If you get 7.5V you are in business with VT-62 / 801A.
I went Hytron because of this: www.worldtubecompany.com/mm5/merchant.mvc?Screen=TF-801. Unsure if I have 30s or 40s coming.
FFS if it doesn't for that money you need a better man than Lucasz to sort it out.I believe no way it can work properly in GG2/PAC on 300b setting with 5V filament delivery instead of 7.5V...just my two cents...
Justin don't get blind valve envy those were for his pre. You don't have to have tried every valve.Justin I didn't get those (VT62, 10Y, 801A) to be used in Lampi but my pre.
Post with attitude. Respect.
All tube based DACs are crap. I just made an obviously faulty one more flexibly rubbish. That's why I am where I am.
Seriously though I really like getting self-employed guys working on my gear. The same chap that did my DAC also did a great job on my Accuphase M-60 monoblocks.
Now they are actually good, properly made amplifiers. Ked hates them.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
