Yes, I have one. Great Recti imoAnyone try this: https://wooaudio.com/tubes/usaf596-withadapter-each
It's rated for 60 000 ft height, this is incredible. I'm still amazed by what people could achieve with vacuum tubes back in the day. Also, I really like the anode caps in tubes. Any other rectifiers like that you can use in Lampi?Yes, I have one. Great Recti imo
Lets just say this recti is part of the "must have" recties in the Lampi worldAnyone try this: https://wooaudio.com/tubes/usaf596-withadapter-each
Yup franky sounds good haha the ebay adaptors works. Have used them.Anyone try this: https://wooaudio.com/tubes/usaf596-withadapter-each
Chatham 5R4WGY. Rated to the same height, built like a mofo and dirt cheap.It's rated for 60 000 ft height, this is incredible. I'm still amazed by what people could achieve with vacuum tubes back in the day. Also, I really like the anode caps in tubes. Any other rectifiers like that you can use in Lampi?
I used the Sylvania VT-52 and can run it at the rated voltage in my very heavily modded Lampi.Here’s a link to the VT-52 specs, listed as a “super 45”, whatever that means. Used by the US Air Force for airborne radios.
Not sure why greater height is a challenge. You'd think less air pressure would be kinder to a tube holding vacuum.It's rated for 60 000 ft height, this is incredible. I'm still amazed by what people could achieve with vacuum tubes back in the day. Also, I really like the anode caps in tubes. Any other rectifiers like that you can use in Lampi?
Think about it. Air pressure drops as height rises. Easier on a vacuum tube than sea level, or at least it should be. Less pressure differential.It's rated for 60 000 ft height, this is incredible. I'm still amazed by what people could achieve with vacuum tubes back in the day. Also, I really like the anode caps in tubes. Any other rectifiers like that you can use in Lampi?
Oh damn, they are. Great clue!Chatham 5R4WGY. Rated to the same height, built like a mofo and dirt cheap.
Bigger temperature difference, at that altitude it's colder than in the UK during summer. Also, vibration, when you think about it being on a plane. I believe that sturdier built is better in terms of microphonics. Which are not the case with rectifiers, just overall. Better vibration resistance also means tighter quality control and probably better materials. That's my take on it.Not sure why greater height is a challenge. You'd think less air pressure would be kinder to a tube holding vacuum.
If you're interested there's some interesting prose in the PDF file downloadable from here: http://www.r-type.org/exhib/aaa0590.htmOh damn, they are. Great clue!
Thank you very much! Cool stuff, that tube can really pump some current. Four 300B in a Lampi should be no problem for it. I can only imagine how many more awesome tubes there are to be discovered. Every day less and less, sadly.If you're interested there's some interesting prose in the PDF file downloadable from here: http://www.r-type.org/exhib/aaa0590.htm
I am fairly sure I remember reading the Chatham could take some ridiculously high G force figures but I didn't see anything about that in the link.
Spot on!!!Tube rolling is just plain fantastic. Often I find that upgraditis is just a craving for different and a nice tube change can satisfy the old itch like nothing else….
You must now refer to the 596 USAF by its nom de guerre: FrankiJust got my 596 USAF with Woo Audio adapter. Totally shocking how big of a difference the rectifier tube makes in Pacific…. Defies logic. Very different soundstage from the RK 5U4G…. Not sure there is a “better” here. Perhaps the RK works better with the other 4 RK power tubes I have in, but this 596 is special in its own way, More forward and wider soundstage, crisper & brighter by a tad.
Yessir, Franki rocking Europe 72 Hundred Year Hall near the 50 yr anniversary!! Bliss!You must now refer to the 596 USAF by its nom de guerre: Franki
