So over the last three years, I've spent hundreds of hours trying to tune the bass response of my System. I originally started out with a pair of Rockport Cygnus and slowly added two, then four, then finally six Rel Gibraltar G1s (connected with high level inputs but no variable phase adjustments). The speakers and the subs (and the listening chairs) travelled virtually every square inch of the first 1/3 of my 13.5'x 25' listening room, every recommended subwoofer configuration, from even with the listening chairs all the way to the front wall of the listening room, in both room nulls and peaks; 2x3 stacked and 6 swarmed at the points of highest reinforcement ala the 'bass crawl about' where one puts one, (then eventually two then three subs stacked) at the center listening position and finds the dips and peaks in the listening area.
These are my findings YMMV!!!:
Distributed bass arrays, at least on my Rel Gibraltars, where 6 subs are on the floor at the points of highest bass reinforcement (AKA Swarms I believe), while being the most effective way of energizing the room and extending the frequency response of the system, unless they are perfectly DSP'd (not recommended IMO) and adjusted precisely for phase (timing) response at the listening chair, do so at the expense of attack, speed and definition of percussive components on some recordings.
Some recordings of drums, upright bass and Hammond B3 come to mind that display the issue well.
REF 1: The true torture test for me Dave Brubeck: Take Five - Time Out from 2:00-4:15. The attack of the bass and the drums through this section of the piece should be both lightening fast and separate. This is very very easy to get wrong. There are minute timing differences between the drums and the upright bass. Many main speakers don't do this well at all and almost all subs/mains setups make it worse.
If everything is right, the interplay between the drummer, Joe Morello and the Bassist, Eugene Wright is breathtaking. Huge Attack and momentous bass and drums!!
REF 2: Eagles: Hell Freezes Over - Hotel California. When the kick drum 'kicks' in, the better the leading edge, the more correct your setup, getting multiple subs to NOT mess this up, especially if located behind the main speakers, is a Hurculean, if not impossible task.
REF 3: Patricia Barber, Cafe Blue - Nardis Drum Solo. If your system is right, the kick drum has a separate 'kick signature' from all the other drums in the kit!! This is how it is in real life too, especially if the drum kit is minimally mic'ed.
Don't expect every drum solo recording to show this difference (kick, vs snare, high toms, and floor toms), but this one does.
REF 4: Patricia Barber, Companion - Black Magic Woman. A slightly easier test, but the keyboad clicks and the start of the Leslie should be razor sharp.
Honorable Mention: Hok-man Yim Poem of Chinese Drum: Look I don't consider myself an audiophile (really). I'm a music lover who loves good sound. But this is an amazingly resolving cut that really tells you what your system is doing in the bottom octave A great combination of leading edge attack and astounding presence, resonance and bloom.
Also, the vast majority of reference bass tracks DO NOT reveal this phenomena!!! Reference Electronica or Organ music or cuts like Boz Scaggs' "Thanks to You" lack the percussive components and cues to hear this effect.
Well those are my four reference Percussive cuts. I'm hoping more will show up here.
Here are my closing thoughts
The most valuable thing to spend on one's system is time.
There are a million wrong ways to set up subs, and only one right way, which is probably why subs get such a bad rap.
You have to try a lot of subs to realize you don't need a lot of subs.
At a minimum, you need two subs, they must be sealed enclosure, as port totally defeat what were trying to do here; and ideally the driver(s) should be bigger than the largest driver of the main speakers.
I have heard dozens if not hundreds of sub setups located behind the main speakers, only three of which passed the REF1 'Time Out' test, REGARDLESS OF COST. None of the setups with subs in the corner or along the front wall can do what these cuts can do.
TO MY EAR, SUBS MUST BE PLACED so the acoustic centers of the subs are in line with the Acoustic Centers of the main speakers, if they are a little ways back, and variable phase adjustments are possible, they might work, but I'm not sure. I know there are schools of thought that subs are not directional (below 100 hz or so), one only needs one to fill in the bottom etc. These do not concur with my findings despite my subs low pass filter currently set to between 24-30Hz (my preference is drifting towards 30 Hz) and the Bayz Courantes running full range (anechoic spec -3db at 27 Hz).
I think there were literally dozens of times I was ready to sell the subs over the last three years.
However, now that I have found MY best sub locations, I'll never live without subs. Two for sure.
The extra 5-10 Hz is absolutely critical, even if your mains go down to 20hz. The easiest things to hear are, believe it or not increased soundstage width, depth and general ambience, finally followed by the extension to approximately 18Hz..
For my room, The additional two pairs of REL subs (from 2 to 6) provide only 1-3 hz extension with dramatically more complicated setup issues. My extra two pairs are now for sale.
Final position of my 2x3 REL Subwoofer Array with the Cygnus.
My current setup with two of the original six REL subs and my Bayz Courantes. So far I have found the best bass response is where the acoustic center of the subs is aligned with the acoustic center of the main speakers.
