If the goal is to reproduce the live event, then every single sensory trigger must be reproduced exactly. Any arguments about that?
I have come clean already, you can check further details in the Member's Gallery. You will note there that there is a subwoofer in the equation, which certainly helps but is not essential. At the moment it's not functioning but that's only losing me information below 200Hz. As I point out, if the amp is behaving itself then the volume output is adequate to reproduce the musical event over the rest of the audible spectrum.
In my experience, the reason most systems fail to convince is because they can't go loud enough without generating too much distortion. It doesn't matter how many bass drivers you have, it still won't work; the only benefit is if the bass area is driven by a separate power amp, taking the load off the amp doing midrange and treble.
Frank
What is the impressive thing about live sound is its tremendous intensity combined with lack of harshness, making it relatively easy for the brain, depending upon the actual volume of the sound, to focus in on part of the wall of sound and to hear some detail clearly. An example with a symphonic work would be a triangle struck lightly during a fortissimo. Now, with my system working properly I have no trouble getting that, and to put it in context, I will now work out some volume figures for my miniscule system.
A key thing is that I can drop the volume while listening like this and nothing changes, it's just as if I'm moving further away.
Without harshness, Tim, without harshness. Remember, that is what the Truth and Tonality dialectic was all about: Robert said it was easy to find/put together a system giving you oodles of detail, the trick is to have it also sound musical. I've listened to dozens and dozens of very expensive systems at dealers and people's homes, and the one area where they inevitably fail, over and over again, is that they are not "musical", a shorthand for saying they distort. Put on the right recording, yes, sounds very impressive; put on a "difficult" recording, they are execrable!Is this all you've been going on about? The ability of small details to come through clearly out of a dense wall of sound?
Exactly, and to terryj, if you check my Gallery posts, there is a photo there of the gear, note subwoofer, note the HT receiver is smart enough to not send the bass signal to the full range unit, so the little fellow is not stressed at all ...Actually, you do have a couple of things going on with those 3" full-range drivers that could result in some of the stuff you're hearing -- 1) They're the right size for "full-range" drivers or, more accurately, for mid-range drivers that will do pretty well at reaching up into tweeter territory, while rolling off early enough to eliminate much opportunity for harshness 2) No crossover.
This is where most people seem to have a problem with what I'm saying, and is the nub of what I am saying here! I will repeat: "In my experience, the reason most systems fail to convince is because they can't go loud enough without generating too much distortion." Hence your system will fail to sound real, because what you call harshness, what I call distortion, starts becoming obvious as you up the volume. I have repeated this point over and over and over again, and it is still not sinking in!But you can turn it up to full volume without harshness? Man, that takes some serious expectations...
Thanks, Mark, for bringing that up. I have not yet added a third installment to my rundown in the Gallery forum, where I will go through the various items I dealt with, but a quick summary is as follows.Uh Frank, how did you *fix* the distortion from that Phillips mini-system-home-theater-in-a-box? The distortion figures of the little Phillips system have to be an order of magnitude greater than the distortion of the amps built into Tim's speakers.
Frank
YepIs this it??
All power to you if you enjoy it. But to say for one second this is capable of sounding like a live performance of anything?
The atrocious FR alone would rule it out of being capable of reproducing a single voice, let alone a symphony orchestra.
Your reasoning is specious at best. You seem to lay emphasis on playing a certain volume without distortion., Ok, then we turn it up till just before it distorts and bingo, per you, capable of playing live music.
What about frequency aberrations??? Not sure what definition of distortion you are using, but per MY book 'any departure from accuracy/truth' etc qualifies as distortion. Your Fr alone rules it out as being 'distortionless'. Per that definition yours are distorting no matter WHAT volume you are playing it at, loud or soft.
I come from completely the other direction. I have an extremely high regard for speaker drivers, early on I was quite astonished how capable they were if you gave them half a chance. Main problem with my HT units is that the suspension has to be warmed up every time to get good results, if I hit them with very high level treble for an hour or so this usually does the trick.And, let me tell you, the electronics are NOT the weak point of your system
Yes, that is totally correct. As I just mentioned, with very heavily compressed material the amps have and probably will often shut down because the internal protection circuitry is saving the IC amp from cooking itself. But I have had the last movement of Beethoven's 9th at max with no problems.Frank, let me confirm one thing I thought I heard you say: Did you say you could turn your system up to full volume without distortion?
Tim
Yep
I have stated many times that FR is not relevant to the capability of a system to sound live.
Frank
Okay, so why do Tim's 2 headphones with hugely different FR's do the job? Of interest, the Philips has some FR fiddle circuitry in the volume IC, normal silly stuff: Digital, Jazz, Classical, settings called that sort of thing, big cuts and boosts all over the place. When the system was in the raw state it was obvious the changes this control made; but when working well it is totally invisible, you can flick through the settings and you can't pick that anything's changed.I just can't let this one go. Of course it's relevant. Live music has a wide-open FR. Chop off any part of the FR, and you have chopped off part of the music which kills any chance for a system to sound live. It would be like trying to duplicate a recipe but leaving out part of the ingredients. It might still taste ok, but it sure won't taste like the original dish. Even if you swear it does, it won't make it so.
Why is this so? I believe because the ear/brain is a pretty smart piece of kit and automatically ignores these changes as not being relevant when the musical message is strong enough, what Gary calls psychoacoustic behaviour...
Frank
So, I will say it for the 999th time: your speakers are not the problem, the problem is that the electronics are stressed as you wind up the volume, plus the inherent distortion due to a myriad of weaknesses are magnified as you increase the level, that's why systems just sound loud, not real, at high volumes! Why do I say what to most people is an obviously ridiculous thing? Because I have played around with gear for nearly 30 years, and everytime I had a problem where someone could say, "it's too much for the speakers", it never was, it was always an electronics issue.
Sorry, Tim, that's just the way it is, and I'm afraid I couldn't live with your setup because you're certainly implying that it distorts as you increase the volume ...
Frank
No, as you carefully chose to ignore, it's mainly because I modified the functioning of the power supply within the unit, and then because of the system being manufactured as an integrated unit the volume control was not engineered to be able to ridiculously overdrive the power amp section, as is the case with the usual pre and power separates.So...you're running the amps in a cheap home theater in a box flat out, and they're not clipping because you hard-wired the speaker cables to the amps and dealt with noise getting into the power cable?
The current paradigm is that it is impossible to achieve realistic sounding playback in the home, and this belief must be defended to the ends of the (flat) earth, against all comers, to the death even. Bit of a shame, really ...
Frank
terryj, this thread kicked off because DaveyF was bewailing the fact that you couldn't get the concert experience in one's home. I contradicted him, and in one post went through some rough calculations to point out that in dB terms my system, and in fact most systems, should be to do it.no, you have a misunderstanding.
at the very least what is being argued is that you cannot achieve a realistic concert experience at concert levels with three inch drivers (plus sub).
ain't gonna happen in this universe.
and regarding the money. bass is expensive. good bass costs more, excellent bass, well you gotta be prepared to open the wallet.
