A friend recommended Crystal E grounding box from Japan. It’s cheaper than Entreq and has a small footprint that suits me very well.
Initial impression the drum in The Empire Strikes Back is now more forceful. Same for piano and probably also for other repercussion instruments.
Here is the link to the product website http://kojo-seiko.co.jp/products/crystale.html It’s available from Amazon Japan at a discount
This was definitely covered in the various chat and forum. I have listed a few below and you can start reading them at your convenience, but be warned that they were poisonousAre there any comparisons of M12 to Melco switch? Sorry if this question was asked before.
I see that you are running 100 Mbps on #1, I guess that connects to your DAC, and #2 to the upstream router or switch?Connected the switch to the earth ground of my Linn Klimax DSM/2 Katalyst for the moment. Haven't tried any grounding boxes just yet, that's the next step. View attachment 82271
Out of curiosity from where did you buy the DC cable for M12?This is a follow-up post after sharing my network improvement journey I learned from members in this forum.
So I got myself an M12 Gold and had to wait 2 weeks for the Plixir LPS. While waiting for the LPS I connected the M12 with the stock SMPS between the Melco S100 and N1Z. At first I was impressed at M12’s ability to present the micro details but I also noticed that the music had become cold and lifeless, the musicality had simply disappeared.
To stop the torturing process I immediately unplugged the M12 and connected it to my wireless router to break it in.
Yesterday my 12V6A Elite DC Power Supply arrived. I quickly set it up and let it bed for a few hours before the audition began.
Wow I finally understood why the M12 is so popular amongst the members here. Hearing is believing! It’s like having upgraded to a new DAC, I could now see better where the instruments are located in Driving, the first track of Hans Zimmer’s Live in Prague. The timing of the music is now so perfect and it has got that 3D effects. Previously it was quite flat with music coming from a big black hole behind the speakers.
Listening to the 7th track - You’re So Cool, the timing is so perfect I kinda suspect there’s a super duper high-end clock in inside the M12. Is there one?
I had initially wanted to A/B the effect of having the M12 in my system and without. But it was totally unnecessary and I simply continued listening to the the whole album last night.
This morning I played John William’s The Imperial March. In line with my observation last night, there was clearly more definition in the music, it’s like watching a 4K video vs full HD. However, when the trumpet came in, there’s a slight loss of airiness and dynamics.
I have a love-hate relationship with Patricia Barber recordings. When I first listened to her Cafe Blue album, I found that the recording was superb but the music sucks. Subsequently as I upgraded my hifi system her music became more and more musical and lively. I always use this album to audition for musicality. And with the M12 there was a slight lost in the sparkles and musicality
To be fair the LPS and DC cable had fewer than 24 hours on their clock. I also read that the Telegärtner LAN cable also need long breaking-in hours. But overall I’m very with the upgrade at this juncture. Hopefully with more time the music will become less clinical.
The LRES 4006MT-PoE uses a unique X-Code cross shield to isolate four communication signals for signal integrity, while its rugged and durable characteristics make the modified product ideal for wet and other harsh environments, such as field monitoring, railway monitoring, industrial production, etc.
I bought a Telegartner M12 switch and it arrived today. Out of box, it sounds reasonably fine but I found it a bit muddy though the bass sound clearly more than my Melco S100 while it has a smooth sound, quite warm. I hope it can provide more resolution.
It is a bit weird to describe the sound of M12 as “analog” for such a typical digital gear. But it really brings a touch of analog taste.
Can anyone advise if M12 will need some burn-in hours or the sound is stable out of box? I am looking for a DC cable so that I can use my KECES P8 with its 12V output. The M12 has quite a wide range of voltage from 10v-60v. I assume 12V would work?
I was following some tips from the threads above. I grounded it to an electricity supply box into the dedicated ground board. I does sound clearer and more transparent than without a ground.
I connected 3 Telegartner network cables to Melco, a streamer (Auralic Aries G2.1) and a Roon Core (Innuos Zenith MK3). However I found on the M12, the LED is flashing in orange. Does it mean it is a 100MB connection instead of 1000MB?
I assume those should be 1000MB sockets?
You don't need more than 100 to stream hi res. Mine is the same, green incoming, orange to my DAC. Don't stress about it, I don't and the sound is absolutely sublime.I bought a Telegartner M12 switch and it arrived today. Out of box, it sounds reasonably fine but I found it a bit muddy though the bass sound clearly more than my Melco S100 while it has a smooth sound, quite warm. I hope it can provide more resolution.
Thanks
Volent HK, the official dealer in HK put it on a Taiko panzerholz board with good effect.I also tried to put the switch on a anti-vibration board. I felt there’re improvements but not very much sonically visible. One puzzle is this switch is narrow .
Pls also consider the Plixir Elite Series LPS from Singapore.I’m wondering whether the performance would improve if I change the LPS into JCAT or Uptone, or Ferrum? Not sure anyone had such experiences in comparing among different LPS’s.
Thanks CK. I have a Melco S100 but didn’t try to connect to M12 via its 100M jack. You solve the riddle of the LED color. Normally green is fasterIt took me 2 weeks to a month to run in the whole M12 setup. I read that it’s due to the Telegartner LAN cables that require long burn-in period.
I also read that 100M/Fast Ethernet connection sounds better but I will get an error in Roon when playing hires files. So now I connect the M12 exclusively to the 1000M/Gigabit Ethernet port of the S100. I can’t hear any difference to be honest.
My M12 is connected between the Melco S100 and Melco Z1. In my case “green” is 100M and “yellow” is 1000M.
Below with the M12 connected to 1000M port of the S100:
And here when it’s connected to the 100M port:
