I've had 20.7's for about five years now and the news on the 30.7's is definitely very exciting! The big Maggies are not perfect (but, of course, NO Speaker is perfect). To add a little impact to the bass I use two REL G-2's (running these at VERY low levels, 27hz and about 1/5 on the volume control). This setup has worked great for me! However, the possibility of removing the RELS and using the much larger matching Maggie woofer panels definitely sounds like a prescription for a Major Improvement! I'm anxiously awaiting an opportunity to hear the 30.7's.
A comment on Amps for Maggies. For several years I tried MANY different amplifiers on my 20.7's; most failed miserably!!! I tried several "well respected high powered SS amps, in the range of 350 watts per channel to amps that were 500 watts per channel that claimed to double into 4 ohm loads. (I did not try the big Bryston amps which is what Wendell at Magnepan always uses at shows). Most of the SS amps that did actually work would start to sag and struggle as the volume levels got higher, oftentimes they would blow a fuse or simply shut off.
Then, I happened across a review by Jonathan Valin in The Absolute sound on the new Carver 305 tubed mono blocks. He emphatically said the the Carvers WERE THE TUBE AMPS for Maggies; he was right! I did some additional research and found two other very complimentary reviews of the Carver amps, one by Dick Olsher and one by Peter Breuninger (AV Showrooms). The Carver 305's (now the 350's) use 6 KT120's output tubes per side and let me tell you that they will drive Magnepans to ear blistering levels and NEVER break a sweat!!! They do not strain, fail, blow fuses, or compress the sound, or even get very hot (you can literally put your hands on the tubes without burning yourself).
Enough of the commercial for Carver; if you own Magnepans you should try a pair of the 350 mono blocks! Also, I have had my 305's for over four years and I am still using the SAME output tubes; Carver claims that they will last at least 20 years (I'm not sure about that, by so far so good).
