Metadata source for dBPowerAmp?
Macattack
224
145
395
SC Low country
I recently tried to rip some CDs using dBPowerAmp after almost 14 months off. However, there are no functioning metadata sources for DBPA.
I know Gracenote is working with iTunes but DBPA has been my go to ripper for 5 years.
Does anyone have a suggestion or solved this issue?
You're explaining the behavior of an expired trial.
Either fix your license or download the current version.
I have had a long term license but will check that out.
I haven’t had the chance to sit down and dig into this further but in thinking about it, I have a license for DBPA and it will rip a CD without metadata. I have through the years, purchased lookups from CDDB or FreeDB. When I did try to buy more this past weekend, I was greeted with that service is no longer available. I see they have been shutdown.
So the question is: is anyone using dBPowerAmp now and what metadata service is working?
