That was the thing I noticed first, the Kleos is fuller in the bass and lower midrange than the Delos. However, it is not a warm cartridge like my wood bodied Benz Micro, but definitely not thin or strident. It is the most neutral cartridge I have had in my system. Extremely quiet in the groove, very fast and dynamic (like the Delos), and very detailed throughout the whole range.Every time I try a new cartridge the Lyra Delos ends up back in my system...however it's a love hate thing....the Delos lacks just a bit of weight that other cartridges seem to have, especially with brass instruments....perhaps it's time to up the line!!
This is excellent! I've been a Delos user since 2016 and just got a new one but now thinking I will exchange it for a Kleos. My local dealer will be sending me one to demo for a couple weeks. I'm sure I will tell him to order one...I now have approximately 100 hours on my Kleos. The sound has opened up quite a bit, especially the top treble. I am thrilled by the sound I am getting, the best ever for me.
The Kleos is very responsive to setup. Tiny changes in alignment, azimuth, tracking force and VTA are easily heard and very worthwhile. When you get it right you can really hear it.
The Kleos is not a warm sounding cartridge like my old Benz wood body. Nor is it a lean or cold sounding cartridge. If the recording Is sweet and warm, thats what you hear. If the recording is thin or strident, that’s what you hear. Nothing is glossed over or altered. In my all tube/full range electrostatic setup this works great. In a solid state state system with metal dome tweeters the Kleos might be too neutral. But probably not.
The Kleos is first and foremost a detail revealer. I know it is a cliche, but honestly I am hearing things in records I have played for 40 years that I never heard before (not even with two Delos’s). These tiny details make the sound seem less electronic, more real sounding. The added information also aids in imaging. The speakers disappear (not easy with 5’ by 2’ electrostatics) and the center fill is excellent. Amazing.
Very happy with the Kleos, I can definitely recommend it for anyone shopping for a cartridge in this price range.
If you can swing it I think you will be happy. The difference is not night and day, the Delos is a great cartridge. But the Kleos does everything the Delos does just a little better. Totally worth it for me. Hopefully they will have a Lambda version of the Kleos out for my next one, the Etna is way out there for me price wise.This is excellent! I've been a Delos user since 2016 and just got a new one but now thinking I will exchange it for a Kleos. My local dealer will be sending me one to demo for a couple weeks. I'm sure I will tell him to order one...
Thanks for your review!
Cheers
Having just went from a Delos to an Etna(older non Lambda) I can tell you that the Delos is worth every penny it sells for. There seems to be a point in this hobby where things get incrementally better at a cost of several more thousands...and the Delos packs it all in at 2K and that may be the point where cost vs dollars paid is the best bang for the buck. Everything after that gets much more expensive for less in return...If you can swing it I think you will be happy. The difference is not night and day, the Delos is a great cartridge. But the Kleos does everything the Delos does just a little better. Totally worth it for me. Hopefully they will have a Lambda version of the Kleos out for my next one, the Etna is way out there for me price wise.
I've had the Kleos on loan now for about 3 weeks. I think the loaner has a slight, very slight bend in the cantilever so the performance may be off. I have to skew the cart more than normal to align the cantilever.......but even with that I am getting some added benefits of the Kleos over the Delos. I've advised my dealer to go ahead and order me a Kleos, I know Lyra is behind in production so will be at least 2 months out. The biggest benefit I notice is surface noise dropped quite a bit. And that's saying a lot since I always had low surface noise with the Delos.......If you can swing it I think you will be happy. The difference is not night and day, the Delos is a great cartridge. But the Kleos does everything the Delos does just a little better. Totally worth it for me. Hopefully they will have a Lambda version of the Kleos out for my next one, the Etna is way out there for me price wise.
Everything I have spun so far sounds fantastic...Including older records have a new sound. What really helped was the Wally Tractor, I had been suspicious of my previous protractors just not giving me the desired outcome.Catcher10 congrats!
Enjoy your Kleos, it will get even better after the first hundred hours.
Listening to this record and can't stop smiling at how dynamic it is, as the resolution is stunning with the Kleos..........Everything I have spun so far sounds fantastic...Including older records have a new sound. What really helped was the Wally Tractor, I had been suspicious of my previous protractors just not giving me the desired outcome.
The Wally is very involving and takes a lot of patience to use, especially getting used to the mirror surface and the arc line, super hard to see that you have it spot on. The cantilever alignment is easier, but setting overhang with the arc line is really an eye strain!! After all that the Foz meter readings were spot on...
Soundstage is widest I've ever experienced as well depth and 3D is cra-cra.........I'm happy!
