Ted, I know how you must feel. I'll be roller skating at Rivergate during the Super Bowl. I skate for 3 hours with maybe at most three 10-minute diet coke breaks, so I'll miss most of the game. I begin my preparations at around 6:30 cst to be on the floor at around 8:15. Skate lasts until 11:30.
So, I'm going to choose your SRX XL line for two reasons. It's your thread and if I had the budget, your gear would very likely be the gear I would choose. I'll let you or my dealer decide the conditioners.
Next would be the speakers. That's easy for me. My choice will be the Wilson XVX with dual Subsonics which means 4 extremely powerful mono amps. My amps will be the brand new MC2.1KW's and I will need four of them. Since they are only 50K a piece they are a bargain, and this allows me great flexibility with my wires. McIntosh sounds superb with solid silver. I'm a great believer in silver wires that are absolutely topline, and your gear would fit my bill perfectly and the Mac gear will keep costs under control. I would want 7 20-amp lines and 7 power conditioners (your choice) with appropriate speaker cables and balanced IC's. One for each XVX and two for each Subsonic so that for the Subsonic, each 1,000-watt power module had its own conditioner and 20-amp line. They are quite inefficient. Everything will be run off the 4-ohm taps. One power conditioner for the pre and sources to make seven.
Next will be the preamp and sources. Again, that's easy for me. My choice will be the C-12000 and the MCD12000. Why? Because I know what the gear sounds like and I love the tube sound they impart to all my music. No solid-state DAC or preamp can match it or duplicate it. It's a well-kept secret how good McIntosh sounds with solid silver and because of the relative cost of the Mac gear, I can utilize your gear to the fullest and still stay well within a reasonable budget.
If you noticed, I don't do vinyl. it's way too much trouble and expense. The above system will have superb resolution and sound analog simultaneously. You manufacture the full gamut of gear that I would want. Just go to your website and pick out my gear for me for isolation, passive room treatments, footers, etc. It's like going into a candy store for me, and the cost savings of no ultra expensive turntable and arm, no gazillion dollar 5 component DAC, and 300K mono amps, and 170K pre's, etc. make my world class system come in at I estimate at around one million.
The only thing I would add is a pair of MC3500's, if I could have absolutely everything I wanted. They would sit adjacent to my 2.1KWs for my XVX and I'd just change out the connections. Wouldn't take 20 minutes. Then I could run all tube to my XVX and solid state to my Subsonics, if I want. .
Folks that use Subsonics usually don't supply them with nearly enough power. These subs will absolutely need one 2.1KW per channel and the wires will need to be of the same quality as the mains. Again, the relative cost of the Mac gear to the ultra-high end like Vitus, Gryphon, CH-Precision, or dCS, make full utilization of your superb gear possible at a reasonable cost. The subwoofer system runs independently of the XVX. The XVX runs full range.
One last thing, I'm a great believer in
synergy and sonic signatures. If you noticed all I have basically done is replace my AQ with Synergistic. You have an absolutely amazing website. You make literally everything that anyone could possibly imagine and it's handmade, imbued with silver, and made in CA. Although I have never heard of you, it can't be a coincidence that your name is Synergistic because you make the whole shebang. My world class system will be entirely handmade in the USA, by McIntosh, Wilson, and Synergistic.
Charles Updated System: Wilson McIntosh Audioquest
Amps: McIntosh: MC3500MKII (2); MC1.25KW (2); MC2.1KW An
Preamp: C-12000 An
Sources: MCD12000 An; MVP881; MVP851; MR87; Marantz 510LV; Lenovo Yoga laptop
Speakers: Wilson Chronosonic XVX
Sub-Woofer: Wilson Thor’s Hammer; Wilson ActivXO Stereo Electronic Crossover
Cables Main System AQ: WEL Signature speaker cables; 24’ balanced IC; balanced 1-meter Dragon IC ; WEL Signature digital, Coffee digital coaxial cables; Diamond optical (2); Diamond USB; Dragon (5 HC, 3 source cords); Thunder & Monsoon power cords
Cables Subwoofer System AQ: Redwood speaker cable; Wolf balanced subwoofer IC; Wind balanced IC to ActivXO; Hurricane HC; Firebird HC; Firebird Source; Dragon HC, power cords
Power Conditioners: AQ Niagara 7000; Niagara 5000 (3); (4) dedicated 20-amp lines.
Isolation: Wilson Pedestals; Bassocontinuo McIntosh Ultra Feet; X-material plinth
Cabinet: Double Custom Woodwork & Design (CWD)
Acoustic Treatments: Room and Echo Tunes
