Such a configuration causes the individual subs to act as separate sound sources. Separate sound sources interfere with one another, causing comb filter effects.
I'm sorry but "comb filtering" at such LFs in a small room is simply not a factor.
Subs should not be placed in a spaced-out configuration. Such a configuration causes the individual subs to act as separate sound sources. Separate sound sources interfere with one another, causing comb filter effects. Also, there is a decent article written on this.. Google "power alley effect" and you can read it for yourself.
Here you go:I would very much like to see some of these JBL studies. If there is anything online, would you please point me to the sites where I can read them?
Mark, are you talking about stereo bass instead of dual, quad, etc., mono bass?Finally, nothing in this article invalidates what I stated about interference between two discreet LF sources. In fact, it doesn't even raise the issue. It focuses upon exciting room modes in an effort to smooth response.
Can it not be argued that if you can localize a sub then the system is not properly calibrated for that sub?... Not to mention the fact that sound originating from different directions other than the 'stage' area, would be confusing to the observer.
My only facts are my personal listening experience and the work of professional sound reinforcement engineers in this field of study.
Earl Geddes's position on multiple subwoofer placement is, essentially, that three subs are needed and you don't need to put the subs at specified locations. I know Frantz is a strong advocate for Dr. Geddes's approach. There seem to be some basic rules that apparently have proven to produce the best results:
- Put one sub in a corner close to the mains speakers. Location for the second sub is flexible with the one condition that it should not be in a corner. Side wall or back wall, near the midpoint is preferred. The third sub goes wherever one can put it that is not too close to the other two. And, finally, I believe Geddes recommends getting one sub off of the floor.
Dr. Geddes, in my first post in this thread, which served to open up the discussion, I wrote:
A couple of questions. First did I torture your position or did I get it (essentially) correct?
Second, if I do have it correct that you recommend getting one sub off of the floor, can you explain why?
However, when we here a concert orchestra, the bass comes from the stage, not behind us, so I see a problem with this setup for such types of music.
