Hello HornJunkie,
i use around 20 years DSP crossovers with magnetotatic speaker systems and will give you some information. Hope can help you little bit.
1. STANDALONE dsp-crossover with Master Volumecontrol 2x4 way
I think this new dspNexus from DANVILLE SIGNAL now the best Standalone product on the market.
Price around USD 3.000,-
https://danvillesignal.com/dspnexus-dsp-audio-processor
This crossover using WEAVER AUDO software for programming all the crossover function like delay, high,low,bandpass- filters, etc, etc.
It is a very flexibel modul system, ..with realtime listening control if you change parameters.
Video how WEAVER AUDIO software work and programming
A other option for a good DSP Standalone crossover is maybe this from the Australia company ANALOG pRECISION. I personal not like this company because they are very unriendly to me if i ask some technical questions like, ....What are the real DSP process resolution? ...How many DAC Chips you use for the 8 output channels? ...i also asking critical questions about there technical specification they give on the homepage, etc. They don`t like my questions. But i will show you this product, maybe you like it, because have many analog Input option inkl. phono. I`m not sure how good the product from ANALOG PRECISION really is.
analog-precision.com
2. DSP CROSOVER using a PC for DSP processing + Windows crossover software + Multichannel Soundcard with master-volume-control
a) You need a fast Audio PC - optimized for Audio for Highend.
b) You install a player software like JRIVER etc. and a good multichannel crossover software on the PC like:
DEPHONICA (great value for money)
https://dephonica.comekio
or
EKIO http://www.lupisoft.com/ekio/
c) You need a very good 8-cannel USB-DAC with master volume-control like one of this:
- OKTORESEARCH DAC 8 PRO (great value for the money)
https://www.oktoresearch.com/dac8pro.htm
Review and measurements OKTO DAC 8 PRO:
https://www.audiosciencereview.com/...d-measurements-of-okto-dac8-8ch-dac-amp.7064/
or
- EXASOUND E68
https://www.exasound.com/Products/e688-channelDAC.aspx
or
- ACKOLAPS ---- High quality 8-cannel DAC with I2S and USB Input.
New- AK4499EX or ES9039PRO-based DAC in stereo, mono or multi-channel mode
www.ackolabs.com
......there give much more like from Merging, RME, etc, etc, i show only some with good sounding and with master-volume-control.
3. Windows PC for DSP processing, with 8-channel I2S PCIe digital output card + 4 Stereo R2R DAC boards with I2S Input + master-volume-controls
This option is very nice and very good quality, if you have a little bit electronic DIY know how, ...or you have a friend who help you.
You need this parts:
a) fast good Audio optimized PC ( same like in point 2 )
b) this high quality PINK FAUN PCIe card, with 8 channel I2S digital outputs on 4 HDMI connectors.
triplemaudio.pl
c) Windows crossover software DEPHONICA or EKIO
(same like in point 2)
or
d) 4 pieces of SOEKRIS DAM1021 Stereo R2R DAC boards with I2S Input
Home page for Soekris Audio apS
www.soekris.dk
Info: You can make master-volume-controls for all 4 DAC boards very easy, with using a 4-way 10k potentiometer, ...connect 1-way from the potentiometer with every board. The Audiosignal run NOT over the pot, Potentiometer is only the reference resistor for the digital output volume control on the board.
Use a 4-way Potentiometer 10k without or with motor for remote control..
https://www.aaranis.com/index.php?main_page=product_info&products_id=395045
In the next 2 infolinks you can see and find more information about, how to make a volume control with this Soekris R2R DAC board, ....what power supply this board need, etc., etc. ......
https://th.aliexpress.com/item/32911158189.html
Soundsample with using this SOEKRIS R2R DAC board only as a bridge for 2x4way active system. Good sounding system from a friend in Bangkok. He use for the high an mid tube amps and digital amps for the low and woofer. Open baffle speaker system for low price, but sound good with active crossover.
Best regards
Chris
PS: I`m not a friend from DEQX. Why? In my opinion the value for money is not the best and you lose to much dynamic with DEQX.
I listening one time system with DEQX. Sorry, i not like.
Add. Picture from my old system with "Fischer Antheus" speakers with 4 inside 12inch Iophon PLS320 subwoofer and FOSTEX Magnetostatic speakers. With 2x4 way active DSP crossover system from TACT AUDIO and a CD-Drive from AUDIOMECA. This system is from 2004.
Now i`m planning to make a new system.
