Munich High-End 2018 Ron Report: Westend Audio Systems Monaco
16,222
13,687
2,665
Here is a new integrated tube amplifier from Westend Audio Systems:
The Monaco's specifications:
FREQUENCY RANGE:10 HZ - 40 KHZ (+/- 0.6 DB)
TOTAL HARMONIC DISTORTION (THD):1% (1 KHZ)
SIGNAL TO NOISE RATIO:> 95 DBINPUT
IMPEDANCE (XLR):17,6 KOHM
TUBE LINE-UP: 4X E130L WESTERN ELECTRIC, 4X ECC82
FEATURES:REMOTE CONTROLLED, AUTO BIAS
INPUTS:3X XLR, 2X RCAOUTPUTS:1X XLR VARIABLE, 1X RCA FIXED
CIRCUIT:CLASS AB PUSH PULL
SURFACE VARIANTS:ANODIZED ALUMINIUM, CHROME, SPECIAL SURFACES UPON REQUEST
LOUDSPEAKER IMPEDANCE:<= 4 OHM
POWER OUTPUTS (RMS):2X 100 WATT (ULTRALINEAR)
POWER INPUT:APPROX. 170 WATT
DIMENSIONS W X H X D IN MM:470 X 222,5 X 373 MM (DEPTH INCLUDING SPEAKER CONNECTORS)
WEIGHT:46,0 KG
