I think you are confusing the Diva with the ScintillaCongratulations on your acquisition, of an all time great.
I humnlysuggestthis speaker can r up to 1ohm. Common to ribbon tweeters. It his a bear to drive. However the resultant sound quality is well worth the effort
I think you are right. I have not heard the Scintilla since mid to late '80s. I have seen pictures. I attributed the difference too modification.I think you are confusing the Diva with the Scintilla![]()
No need to be sorryI think you are right. I have not heard the Scintilla since mid to late '80s. I have seen pictures. I attributed the difference too modification.
Sorry. Age is humbling.
Congrats are still in order.
That depends on the guy who re-did the x-oversCan i ask, how many power amps are required?
Hey Chris, here is a little bit on the physical difference btw the TSW Ultimates and the Extremes - I have articulated the sonic improvements a bit in the other posts. The mechanical differences are that the Extremes have redesigned all new foil only ribbons a la the Full Range. They no longer have the Kapton/Mylar? backing. Rich also told me he has incorporated a significantly improved foil driver mounting / damping process. I don't know the details. Also the crossovers are fully new designs.
The original Divas had a bi-amping (-wiring) terminal.
I would say between 2 and 6 channels
I had my ex-Scintillas made to accomodate a tri-amping (-wiring) terminal![]()
Wow! If I understand correctly, bass driver is foil only too, not just the midrange and tweeter? Is that correct? That would be a dream come true!
Do you know if higher efficiencies are possible? The Synergy and Definitive were 95 and 100db respectively, using incredibly powerful magnets, is possible to combine them with with the foil only drivers and transformers to arrive at something like a 16ohm/100db speaker? (I suspect price will climb like mad just for the material costs, but just curious about this)
Beautiful! Please list all the associated equipment as well!
Lee
Are you sure also the bass panels are foil only?Yes, all drivers are foil ribbons. You would need to discuss the rest of your question with Rich. I don't know.
I seriously doubt that.
In the Grand, the FullRange and the Scintillas the bass panels are Kapton backed and the bass panels of the Studio Grand/Studio Ribbon Array and the Mini Grand/Stage are Mylar backed.
Thanks for the updateThis is my understanding from all my conversations with Rich, but I guess it is possible there is a backing on the bass panels? I will ask Rich the question directly and let you know.
UPDATE: Chris, I heard back from Rich and indeed you are correct. The bass panels are backed by a single layer of Kapton. The Tweeter and Midrange drivers are pure foil.
I thought only the Stage/Mini Grand are double sided bass panels, "sandwiching" a Mylar layer between two layers of corrugated Aluminum "foil" and checked but you are absolutely right, also in the Studio Grand/Studio Ribbon Array, the bass panels are double sided.I absolutely adore the sound of the double sided mylar bass panels aka Stage and Studio Grand. However, mylar is not the best or most durable material for these, apparently.
