Impressive drums even over my computer speakers, however the voice suffers. I am wondering if you shifted the tone towards the bass play somehow?
Pop recording is only for fun sir. My system just spitted out what on the record. Play this record in your system and you will hear.Impressive drums even over my computer speakers, however the voice suffers. I am wondering if you shifted the tone towards the bass play somehow?
Sorry for posting my video in your thread Peter. But cannot resist. I just have to show you my great great grand pap cartridge playing this famous 80's pop.
It depends upon both.You realize the depth of bass for this speaker depends on the horn length and not the size of the woofer?
Brian, I always respect your candor. It sounds most like my system when listening through my headphones. Next is the iMac computer speakers, last is the iPhone. It is pretty hard to asses bass extension, weight or slam from these tiny devices, but that is not the intention. Same with most rock videos. These videos are merely tools for specific aspects of the sound and for entertainment. The bass quality is far superior to my prior system on this and other music, and it is not just the wonderful Vitavox 15” paper driver, but also the TT and electronics. In room, this recording is quite something.
We don't know the frequency response of the phone mic, let alone the playback systems being used. I always play your videos, and others, using a portable DAC/amp through headphones. But bass is never going to come across remotely close IMO. So that's why I was asking you, regardless of how it sounds to me, how it actually sounded in the room. It should slam pretty hard. As to hating this track, I was referring to it being over-engineered and artificial. There's no baseline in reality as to how it *should* sound. An ironic track in a natural sound thread.![]()
I'll try to find the posts about your recent power delivery changes, Peter. By recent do you mean post swapping out all your gear and rack and cables?
Hahaha..No vacuum stuff Peter. For convenient sake I often don't put record weight on. The other arm is a very old Ortofon RMG309. I experimented it with the Westrex cart to see how good comparing with the 3012R.@Tango , you and David have my dream TT and cartridges. You chose well. I have to ask, did you add vacuum hold down or did you simply forget to put on the record weight?
It sounds fine especially considering you are recording from the alcove away from the sweet spot. I see you have also been experimenting with another arm. Perhaps you need to drink more of David's
Post #2628 and around it. The electrician made incremental changes during a period of a few weeks and I listened to each one before he did the next one to best understand the impact on sonics. There were four stages.
I ended up with a new dedicated service panel which has only the four 30 amp audio circuits on the same phase. The audio circuits are separate from the rest of the house but everything is bonded and grounded to the water pipe with new wire and connectors.
The overall improvement is significant.
Tang's recording only.Edit: I don’t know if you’re talking about my pop video or Tang’s. For my video:
Based on listening in the room, the tone is more balanced now. Previously there was more high frequency distortion which made cymbals and wind instruments and other high frequencies seem a bit thin, white and splashy. This tilted everything up. Vocals seem actually more filled out now and the upgrade to the power improved the sound with all frequencies sounding more natural to me. The most obvious differences are in the weight and body of the low to lower middle frequencies and improved tone of the highs. Overall, the sound is cleaner and more open across the board, and more balanced overall, not just tonally, but spatially too, and in terms of scale.
I think this is because of a reduction in noise from the grid getting to the system, but I can’t be sure.
Another natural sound power distribution box has taken up duty in my office in my secondary audio system. Hubbel 8300 series receptacles, 10/4 stranded THHN, wired with isolated ground all the way back to the main panel, Ching Cheng cords. It's a simple system with only a TT, phono, and 25W amp needing power. I'll move the TT motor to a different branch, which is already wired to the room, later. For now I'm just ear testing the end result. It's sounding cleaner, less dynamically retrained, effortless, and contains more subtle inner detail. Previously, I had just plugged everything into a Furman PST-8 which itself was probably a severe problem. Power is such a big deal.
Peter, the "whole system" is a phono and a 25W amp. And yes, one 20A circuit with isolated ground as I described. I'll stick the TT motor on another circuit outlet but it's currently plugged in to the natural sound box with the phono and amp. I don't think Furman - the old power strip - can be accurately described as "audiophile", though. But that strip had filters in it and I'm sure they were restricting the sound. Actually the opposite of enhancing leading edges. I'd say the sound is snappier sounding now, if anything. Less restricted sounding. Sharper leading edges, but not enhanced and not fatiguing. Sort of effortless and clear. Difficult to describe.That looks good Brian. Is that just one dedicated circuit covering the whole system? And do you know if the four conductors are all twisted together inside the metal armor?
You describe basically the difference I heard. The 90° metal elbow coming out of the wall is pretty cool. My wires just come up through holes in the floor. I don’t have the MC cable yet but that’s going to be the next listening test. Good decision not to take my JPS in wall wire. I’m sure what you are using sounds better based on the experiments I did. Good idea to ditch the audiophile outlets also. Of course that stuff enhances leading edges and makes the sound more aggressive and impressive, but that edge and thinner tone causes fatigue pretty quickly.
2. Dynamic range is notably increased. I find that I'm adjusting volume more often in the middle of records. In fact, I don't think I ever did this much at all, previously. But now, crescendos in the music are catching me off guard at times. So I have to reach over to turn the volume down to spare my ears and household.
