Considering Dietrich sells all his products through distributors and dealers, there can be no such worries. He has been operating the last 4 years or so quite successfully it would seem with no issues with product or service. I certainly know the Aussie distributor has had no problems.
I saw the Avocator phono in HK in August. It looked very impressive and build quality was excellent, however I was more interested in the giant monolith that was his turntable.
from M&S
Something new is coming from Dietrich Bakemeier and Acoustical Systems team. The EVOcator is Acoustical Systems’ all new full-feature reference tube RIAA phono stage implementing PTFE-circuit boards gel-cushioned for vibration isolation, pure silver foil in oil capacitors, premium grade triodes...
“With the EVOcator we complete our product portfolio as it was the last major component "missing" in the all analog front end chain.”
The EVOcator all-triode-tube reference RIAA phono stage features:
· full feature 4 phono inputs – RCA and balanced - w/3 selectable gain stages for MC
· 2 outputs – RCA and balanced – 600 Ohms studio pro standard
· front panel selectable load for capacitance and impedance for MI and MM
· front panel selectable load impedance for MC inputs
· front panel selectable phono phase 0° and 180° inverted
· front panel selectable Mono / Stereo
· separate power supply with tube rectification and
· DC tube regulated plate supply
· Selectable grounding route for zero hum
· Operates 100 to 250 V ac line – 50Hz and 60 Hz
· Highest quality connections: WBT (RCAs), Eichmann (RCAs choice) Furutech (IEC socket and XLR (choice)), Lemo (power supply to phono stage).
Made with PTFE-circuit boards gel-cushioned for vibration isolation, pure silver foil in oil capacitors, premium grade triodes, top-class RCA and XLR connectors and entirely non-magnetic high dampened alloy cabinets.
Entirely designed and made in Germany.
