Yes you are right, you didn’t actually claim one is better than the other, I read a bit too much into it
I liked my XP-20 when I owned it. really nice SS pre amp and excellent for the $$. Many reviews said the XP-30 was different ( warmer) but not better sounding.
I hope the XP-22 is an incremental improvement.
if the upcoming replacement for the XP-25 can fix its noise issues and get a little more extension up top, it will be a winner. a memory on setting would be great as well.
Thank you for this report, Peter. While I personally am not versed in the Pass Lans line-up I think this report and your future reports would be very valuable and instructive for someone choosing between and among these components!
Peter, nice review, and was pretty much what I was expecting. I love it when a new piece of gear/cable lets me hear new details in familiar music. Looking forward to my own experience once this UPS disaster is resolved.
One question. When you compared the XP-20 to the XP-22, were you using the Revelation Audio umbilical on the XP-20?
Does anyone have a theory on why the Resolution Audio Cable would be making a difference on these PreAmps? Is the original cable not shielded, using an insufficient gauge wire or perhaps not even using copper as a conductor? I know Pass isn't much into tweaks but it is interesting that they would let these PreAmps (XP20 & XP30) out the door using bog standard printer cables if they would have a less than ideal performance outcome.
I get that these are just a Power Cord in the case of the XP20 and a Power/Controls Cord in the case of the XP30 but if the original cable is anything less than ideal already seems odd to me considering the importance of the link when dealing with separate chassis that are dependent on each other.
I'm not doubting those who use them and say they are better but just curious why the weak link to begin with?
1. How many dB per "click" does the new preamp raise the volume? 1dB, 0.5 dB, or 0.2 dB?
2. An factory upgraded Xono or even Aleph Ono is an excellent choice for those on a budget. BTW I have found Pass Labs customer service excellent.
3. Since the new phono stage will drive long balanced lines well (as did the older models), why don't you try putting to 'table and preamp in another room, preferably suspended from the ceiling? You may find the sound improves dramatically. When we had a much larger dedicated music room, we did almost this, viz. we used a wall shell for the 'table. One can try different things.
Enjoy your upgrades!
Hi Peter,... and I use it on my XP-27 phono stage...
