Review: Monsoon High End Speakers
karma
320
1
White Rock, New Mexico
HI All,
Have any of you heard of Monsoon speakers? Probably not. They are a little out of the main stream here. They were marketed as computer speakers. Not excited yet? Well you should be at least after you know what they are. Let me describe them.
They are panel speakers using magnetic technology. Designed by Bruce Thigpen, they are a miniature version of Eminent Technnology's LFT speaker series. The panels measure 8 1/2 inches tall, 4 1/2 inches wide and 5/8 inch thick. Several models were made. I am concentrating on the ones I have which I think are the best. The panels have small adjustable stands so the listening angle can be adjusted. The total height with the stands is 9 1/8 inches. The panel screens and the sub box are finished in matte black. It's a turnkey system with amplification and crossovers built into the included remote subwoofer woofer box. It is a biamped system with sub having its own amplifier. There is a remote controller that can sit on your desk with Mute, Volume and Bass Level controls. All cabling is included. To make it work, you simply plug the main panels in the subwoofer box and then plug into the wall. You do need to connect the sub box to the stereo audio output on your computer.
The basic panel driver technology uses the LFT style push-pull arrangement meaning there are magnets both in front and back of the diaphragm, a basic Bruce Thigpen design. The audio signal is applied to a matrix imbedded in the diaphragm.The subwoofer uses a ported design and is about 6 1/2 inches in diameter.
The performance of the system is astounding. It sounds like a real, expensive hi fi speaker if it's used within its limitations. It has very little in the way of coloration's. It flat sounds real. The sub goes down to about 50 Hz. The high end is excellent as is the midrange. This speaker has little to apologize for. It's hi fi! And it images like a Maggie or LFT. Resolution is outstanding.
But the Monsoon's do have some limitations as you would expect. While it will play plenty loud enough for an office, it won't cut it in a living room. Of course, it is intended for an office, not a primary sound system.
I have a friend who lives in a mobile home. He uses the Monsoons as his primary speaker system and it does very well. In fact, he was the person who introduced me to Monsoon. I use two systems in my computer room, one for each computer. Monsoon also made a surround sound version with four panels and a larger subwoofer. There is no center channel. I use this one in my travel trailer. Again, first rate.
The speakers I have are no longer being made. I bought my three systems off eBay used. The most astonishing part is they were originally sold for about $250. I paid about $80 at auction. Even at full price, these speakers are a great bargain.
When we think of Computer Speakers we automatically think bad things. And that is usually correct. I know I did. But, the Monsoon's completely shatters that preconception. They are fun to listen to. I'm am listening to The Firebird Suite off iTunes right now.
Sparky
Edit: See post #12 for a picture of my model.
Sparky - I had some Monsoon's that I bought new at Costco back in 1999, so some 13 years ago, and I wholeheartedly agree. I unfortunately forget the Model #, but from the size description it could very well have been the ones you are referring to. They were with me for close to 5 years, and I don't think I've ever enjoyed music through active PC speakers more. They were clean, detailed and the sub provided more than enough bass for my liking and in my PC rrom, which at the time measured about 14x20. I only listened to them in the nearfield and never really alowed them to open for the space, but then I wasn't concerned about that. I ended up giving them away to my brother-in-law as I wanted to do some needledrops, and connected a 2ch amp, one of my TT's and some Totem Mites. I will say, I have fond memories of the Monsoon's and wish they were still around.
HI John,
I have been trying to find a picture of my model. No luck yet. Plus, my screen capture program has decided not to work.
Sparky
I looked around for some images a while back as there was someone who mentioned they had Monsoon's (other forum)...I came up empty.
These?
See the earlier big ones here:
http://www.stereophile.com/floorloudspeakers/1001monsoon/
HI Kal,
No, mine are slightly taller and the stand is different. My stands have an angle adjustment. These do not. Also, the sub. I have no controls on mine. But, that's the general idea.
Sparky
I remember being impressed by these hearing them at CompUSA. I'm pretty sure it was late 2000 as I was on my way to Florida for schooling. There was one computer speaker that I actually liked more, also a panel type by a company called FPS from Japan. I don't know if this company is still around either.
Well I just checked and they are still around but don't make computer speakers anymore.
Well whaddya know. My FPS' were from around 2005 or 2006. Funny looking things. Looked like a cross between the Star Trek federation logo and Penguins.
HI All,
In the context of this thread, namely desk top, quality speakers, there is another I would love to hear. It's Magnaplaner's "Mini Maggie" system. It's a pretty recent product and has had some very good reviews. The down side is they cost around $1500. Given that I already have the Monsoon's I would not bite at that price. But, I'll bet they are good.
Have any of you heard them?
Sparky
HI All,
Sparky
The Mini Maggies are good. IMO too good to be limited to a desk. I use the powered Audioengine speakers on my desks at work and home.
My Mini Maggies (with subs) are used as satellite/woofer system as described in this review:
http://www.avguide.com/review/magne..., Antelope & Musical Fidelity; Sony earphones
HI Robin,
The problem I see with the Mini Mag system is its cost. I don't know about you but when I am at my computer I am working. This means that I'm not paying full attention to the sound. In fact, if I'm really working I don't notice the sound at all. That's the way my brain works. Why would I want to spend that kind of money on a desk top system and not listen to it? It makes no sense to me.
The Monsoons are faced with the same problem. The difference is I paid less than $100 for the Monsoon's so they are much easier to justify.
Sparky
