There's a bit more than volume attenuation that goes on when shaving bits Frank. I await with bated breath.
Absolutely, and fully agreed. With many terms, such as those you listed, it's not difficult to understand what is meant. But the people in this discussion are audio professionals, or at least professional reviewers, so it's not a stretch IMO to expect people to use professional terms. Further, what do tonal texture, substance, organic signature, bloom, flow, and focus and precision mean? Those are so vague that they're meaningless to me. And certainly they will mean different things to different people due to the same vagueness. Same for PRaT, which are also vague. If a term means something different to every person, then I don't see how it's useful.
--Ethan
Sorry, Gary, as far as I am concerned you HAVE done the digital record and playback -- that's exactly what the A/D/A loop is!There's more work to do before we can do the digital recording and playback.
Orb-What is the point to showing the tonearm resonances? Is someone doing research to try and improve tonearm design or is this just another finger being poked in the analog eye? I do find this interesting because I never knew about secondary tonearm resonances and I still don't know how audible they are or aren't. I wonder why at this late stage of the game this type of information is just coming out. Do you have an LP set up in your stereo system Orb?
Orb, have a look at www.whatsbestforum.com/showthread.php?2701-Reviewing-the-Furutec-Demag/page22, post #220. In Gary's high end TT, there is just such a resonance all through the track
Frank
if I ask a recording engineer to translate in words what is the effect of "3 dB shelving boost above 4 KHz" what would be his words?
Frank
my fellow listeners know exactly what i am referring to when i use any of the terms on my list. in fact; i'll bet musicians would also have a pretty good idea of those terms too.
Ethan, if you take a digital signal and successively reduce its resolution (in bits). How would you describe the fidelity reduction at each step?
Ethan thinks 16/44.1 is good enough and it sounds the same as 32/gazillion kHz.
I consider both the same. They are simply the ability to resolve the sound as it gets faint. Or faint overtones (if audible) over louder sounds.low-level detail
decay in notes
There we go. You just used a layman term as others used beforeI'd call that quality graininess.
Indeed. Digital impacts audio in unusually and non-consistent ways. A loud movie sound effect is not likely impacted by losing low order bits....But again the sound quality depends on the source. If the source were a single sustained bass note, the sound would probably be more aptly called buzzy of fuzzy.
--Ethan
And importantly any such "8hz stylus trait" can only be applicable with cartridge-tonearm-mounting measurement, so it is classified as a tonearm resonance.
So I personally have no trouble deciphering half the vocabulary used. To be fair though, it is also proper to dismiss the other half as just non-sense or at least non-descriptive.
There we go. You just used a layman term as others used before.
if you chop off the low order bits, you create harmnonic distortion. And what is a harmonic but added higher frequencies.
Put the two together and the sound can become "bright." You won't be able to measure this effect on frequency response measurements because these are transient effect that help accentuate higher frequencies.
As always then, the truth is half way in the middle.
So did 60 other audio people in 554 blind trials done over the course of one year:
The Emperor's New Sample Rate
I think we'd all do better discussing the facts and the science, rather than talk about what Ethan hears and what Ethan thinks.
--Ethan
The harmonics added by distortion are easy to see on an FFT, which to my thinking is a good way to assess frequency response.
--Ethan
You really want to get me started?so which are the descriptive terms that you dismiss as nonsense?
