Without digging back into your thread Peter. Did you measure your room. Before and after you changed systems.
Does the horn measure better?
Rex, I don’t have the equipment to do so. A friend of mine came years ago and measured by room when I had my old Magico minis. I posted those measurements in my sublime sound thread. I can’t remember if we used pink noise from a digital file or from an LP. I suspect they would show different results.
One of the problems with system threads is if they get long and veer off topic frequently, it’s very difficult to go back and find anything that’s relevant to the actual system.
