I knew you were just looking for arguments (as usual), which is why I was hesitate even to respond to your comment.As far as I see it has an output line transformer - not exactly native SE.
Also uses signal transformers and output line transformers.
Not very low output impedance, the manufacturer site says: Output Impedance: 1KOhms, XLR and RCA
Merely having an output transformer, without more, does not make a natively single-ended circuit a balanced circuit. By "natively single-ended" I mean (i) the circuit does not use a balancing input transformer or an unbalancing output transformer, and (ii) the circuit is not truly differential from input to output (where both positive and negative are processed internally with no reference to ground from input to output).
In a natively single-ended design the signal is always referenced to ground throughout the circuit.
