I an sure I would like the way they sound. But the blow-up risk is too high for me.
They probably will not work on your speakers either
There are always the eye gouging, hair ripping audiophile arguments over autoformers with OTL.
Yes, adding a transformer. However, they are not air gapped, floating output transformers with separate windings. They offer some speaker protection by conducting DC to ground. They are a single winding with different taps for impedance and/or voltage control. They do not have the large windings ratios of typical single ended or push pull transformers, usually a max of 4:1.
Autoformers can bump speaker impedance to 16 ohms, where OTL amps thrive. A local audiophile uses Speltz autoformers with his Atma-sphere OTL amp, and his setup sounds great.
I decided to add them to my VFET amps to bring the low impedance ribbons to 8 to 10 ohms. As far as I can tell, they are NOT transparent, because they make things sound better. Higher, wider, deeper soundstage, all suggestion of janglies gone. The dynamics seem to be wider and more linear.
If you associate janglies with detail, that might be disappointing, but I perceive even more detail because I can look deeper into the soundstage and music and the images are larger. They make me doubt the "wisdom" of current dumping DC amps.
The VFET amps already sounded great, so bumping them up was nice.
It would be nice if Ralph could chime in.
It has been very start and stop. Weeks of rain slowed things down.
These things usually take longer than the most pessimistic estimates.
Next Neveruary at the rate our house repairs are proceeding. But thank you for asking.
Oh my, ain't that the truth. My room is done, acoustic curtains finally hung, vinyl cabinet near completion. What is the hold-up — a dozen recessed LED ceiling trims. Ordered wrong color temp originally, returned early December. Then the lighting store guy orders the wrong part... those are out of inventory until late January and not until they arrived did we learn he'd order 2" instead of 4". Back they go. Friday I go to finally pickup the replacements. Oh oh, wrong part numer in their system resulted in the wrong parts arriving once again.
The best of plans and project schedules can't account for and predict the effects of f-ups and knuckleheads.
I won't put my gear in the room as I still need to work the perimeter to install the trims. Knocking sheetrock mud and dust down onto the gear seems silly. At this point it'll be done when it is. Some parts you cannot control.
And then there was my original intention to not do this during the winter rainy season. Epic fail on that!
Best of luck Ron. Patience is indeed a virtue.
Oh my, ain't that the truth. My room is done, acoustic curtains finally hung, vinyl cabinet near completion. What is the hold-up — a dozen recessed LED ceiling trims. Ordered wrong color temp originally, returned early December. Then the lighting store guy orders the wrong part... those are out of inventory until late January and not until they arrived did we learn he'd order 2" instead of 4". Back they go. Friday I go to finally pickup the replacements. Oh oh, wrong part number in their system resulted in the wrong parts arriving once again.
Oh that's right!! I read it has been raining there and that the drought is officially over. I'm pulling for you too Ron and I can't wait to visit you guys over there in southern CA.
