Hi Bruce. Good to see you again.I am setting up a music system at a new home. Straight two channel for now. Ideally:
Roon on screaming i7 desktop in a nearby office.
Dirac or Fab Filter Pro providing digital equalization. (Willing to try Acourate (again), despite the rough user interface issues)
All control via an iPad
MSB stack as my DAC, maybe feeding VTL preamp feeding active speakers
(Not yet sure if I will do volume control in the preamp, or at either the desktop or speakers)
Feed the MSB stack locally with a microRendu or similar Ethernet to USB converter
I know that Fab Filter is 96k limited. I suspect Dirac has a sampling rate at which it works best too. I will "sacrifice" bit and sample rate conversion "sonic losses" for the sonic gains from PEQ.
If I am going to have to resample everything to 96k (or 192k) for Dirac or for Fab Filter Pro, then I suspect I should add HQ Player to the chain? (I currently use J River's built in resampling functionality.)
So, if you were going to use Dirac or Fab Filter remote from the DAC, and wanted to use Roon, with local control via an iPad, what would you recommend as the best playback chain(s) to consider?
Appreciate the help!
On resampling, Roon has its own and works very well. I am having it resample all DSD to it and it has a choice of three different algorithms from what I recall.
Dirac Live supports 192 Khz anyway so no resampling is needed for that. Only DSD and higher sample rates need to be converted which Roon handles internally.
As far as the main system, why not build a quiet PC like I have and use it next to your audio gear? I just documented mine: http://www.audiosciencereview.com/forum/index.php?threads/amirs-music-server-build-thread.415/
Better yet, we wanted to build one for a customer and we handed it to our local computer shop. They came back with an estimate of $1,642 with identical components fully built! All we had to do is give them the above link and we were good to go.
Once you have that, then everything you want to do is there.
