That's no problem at all! If a transformer is silent on 50Hz then it will be on 60Hz as well.You do realise that you will still be running at US mains 60Hz frequency.
Apologies if I am reading this incorrectly… You have constructed a dedicated power spur by simply doubling up two 120V power lines ?
Did you try any of those Linlai 6SN7s in the MA-1s?Finally an observation/opionion from my amp comparo.. I still have the 3 pairs of amps--see a post above--arranged on my lowboy, and last nite I concentrated on my substantially improved Atma-Spere MA-1s v. the Viva Auroras.. The A-Ss sounded as excellent as ever but not as warmly toned as I remember(1) them.. In contrast, the Auroras sounded simply fabulous--very resolving, warmly balanced (to a greater degree than just a little--but never to 'thickness'), and very spacious...WOW.. One term I've never used to describe sound is 'round', but I hope you'll understand that the music sounded more 'round'--and whole--than thru the A-Ss.. I sat and listened, grinning, and sampled disc after disc.. I then tried the Linlai WE845 Western Electric (mentioned above) in the 'Power' position where Elrogs had been and didn't notice any difference..Then I installed the Linlai 845-T2BE(2) in the front position to reduce the combined light output of the tubes; that worked nicely and didn't reduce the SQ. (3)
Next up will be the deHavillands.. FWIW, the A-Ss, Auroras, and Allnics have balanced inputs, the A-Ss' real and the Auroras' and Allnics' presumably simply a convenience, but those inputs eliminate the use of the inexpensive, CHEAP XLR-to-RCA adapters that I must use to drive the deHavillands and Operas.. BTW these various c. -30Watt amps drive my 96dB-sensitive Serenity Super-7s to extremely high levels, so lack of dynamic range is NOT a problem.. And I almost always forget to mention that these amps drive only the MR and treble mag-planar drivers of the S7s.
(1) One reason I'm such a low-degree Golden-Eared Audiofile is that my sonic memory is about 5 seconds long.
(2) The 'BE' means black envelope.
(3) Grant Fidelity offers the same tube versions in 211s as in 845s, so if the Auroras win my comparo, probably I'll buy another a '211WE' for the driver and another 845-T2BE for a full complement of Linlais.
Interesting observation and consistent with my experience with the Auroras and what I have heard from OTLs I have owned and the couple of times I heard AS OTLs. I predict the Allnic will fall closer to the OTL sonically and the deHavilland even warmer (maybe too much) than the Auroras. Opera amp maybe a bit leaner than Auroras. Just speculation on my part...Finally an observation/opionion from my amp comparo.. I still have the 3 pairs of amps--see a post above--arranged on my lowboy, and last nite I concentrated on my substantially improved Atma-Spere MA-1s v. the Viva Auroras.. The A-Ss sounded as excellent as ever but not as warmly toned as I remember(1) them.. In contrast, the Auroras sounded simply fabulous--very resolving, warmly balanced (to a greater degree than just a little--but never to 'thickness'), and very spacious...WOW.. One term I've never used to describe sound is 'round', but I hope you'll understand that the music sounded more 'round'--and whole--than thru the A-Ss.. I sat and listened, grinning, and sampled disc after disc.. I then tried the Linlai WE845 Western Electric (mentioned above) in the 'Power' position where Elrogs had been and didn't notice any difference..Then I installed the Linlai 845-T2BE(2) in the front position to reduce the combined light output of the tubes; that worked nicely and didn't reduce the SQ. (3)
No; they're equipped with Tung-Sol oval-plate 'N7s in the Voltage-gain sections.Did you try any of those Linlai 6SN7s in the MA-1s?
If those are NOS original Tung-Sols, that particular tube has an odd kink in its linearity curve. They fixed that in later production and a lot of other manufacturers never had that problem. You can see this if you find an early Tung Sol tube data manual.No; they're equipped with Tung-Sol oval-plate 'N7s in the Voltage-gain sections.
The Linlai Global Elite E-6SN7...No; they're equipped with Tung-Sol oval-plate 'N7s in the Voltage-gain sections.
The Linlai Global Elite E-6SN7s arrived today.. I plugged them into the deHavilland 845-Gs and warmed everything an hour or so.. Started playing music and discovered one of those amps had about 20dB less level; replaced the LL with a TSOP and the missing gain came back.. Replaced the other LL with the other TSOP and all is good.. The deH 845-Gs sounded very good overall but certainly did not dethrown the Viva Auroras.No; they're equipped with Tung-Sol oval-plate 'N7s in the Voltage-gain sections.
What were the main differences?The Linlai Global Elite E-6SN7...
I can finally eliminate one pair of SETs from my pile of poweramps. Will be having the Opera amp repaired locally next week.
Details you want, huh????What were the main differences?
So, unless the Allnic amps are better, the Aurora was the champion of the amp cluster you bought? Didn't the Opera Consonance amps also die? Did you get them working?Another change of circumstances--the A-6000s are NOT going to Sonic Craft, my buddy and I are repairing/improving them in my musicroom. Will be moving a worktable into there to do, first, the repair work, and then some improvements.
The Auroras still sound and fabulous as ever.![]()
Yes, the Auroras are clearly the best of the 3 I heard. And yes, one of the Operas died; it'll be at the professional-fixist's place for many weeks.So, unless the Allnic amps are better, the Aurora was the champion of the amp cluster you bought? Didn't the Opera Consonance amps also die? Did you get them working?
Interesting. What did you find lacking compared to the likes of Kondo or Audio Tekne?I listen many times new Aurora from distributor and from my friend living 5 minutes from my home had for 3 years Viva New Aurora
I never was impressed from this amp
For me a good amp but nothing special
I don't know a good enough pure transistor amp...Sound is good and have many energy and power,little too full in midbass,very very little roll off and less natural anf magic on mid of kondo and audiotekne
But good with speaker not very efficient,even if at that point i prefer a good transistor
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
