And the 300B amps?
they are good but the 70 are quite better in terms of transparency, weight, nuance, musicality. The 300b have a bit of midrange texture. On the uni too the 70 was quite better
And the 300B amps?
Hi,Before I switch to the upgraded Circle Labs A100 here is my Crossfire III SET , Archie Shepp , vinyl from SteepleChase recording studio.
Ked said this one sounds good so I am bit more keen to post it here
No hocus-pocus, just simple Iphone 12 mini .
Hi Charles,Hi,
What is the title of this recording? Tonality, timbre and musical flow and engagement are apparent even via less than ideal iPhone. Nice body of Archie’s tenor saxophone. Thanks for sharing that.
Charles
Hi,Hi Charles,
The title of the recording is Trouble in Mind, I am now out of home ,will check the title of this specific track after I am back.
Thank you for your kind words.
https://www.discogs.com/release/11453890-Archie-Shepp-Horace-Parlan-Trouble-In-Mind
Mariusz
It seems GM70 amps are on the rise. My GM70 amp has lots of nuance and transparency, with nice tonality but also tons of grunt. Do you know what input and driver tubes are being used in this design?they are good but the 70 are quite better in terms of transparency, weight, nuance, musicality. The 300b have a bit of midrange texture. On the uni too the 70 was quite better
field coil Lowther with Shindo 300b, Thomas Mayer 45/2a3, custom PX4.
Which component is in the front on the left?
how long can he play on 2x230Ah?...AGMs shouldn´t be deep drained to more than 50% as far as I know, which leaves 230Ah
so the system pulls in excess of 55Amps an hour.......easch poweramp maybe 200watt, less than 9 Amps each
what´s the biggest consumer? any active subs around?
JBL 2405 poor man´s ET-703 in this LV version.....can do same rotating trick as 703 in Olympian
There was some rumour the tweeter would be reproduced again?Cessaro bought the remaining inventory from TAD with diaphragms and all
OK cool
How did you like the (modded) AirScouts?View attachment 104117
living Voice Air scouts, with Kondo Neiro 2a3 and compare with audio note empress silver 2a3. Grand Prix Parabolica with Viv Labs tonearm and Kondo IOM cart, KSL SFz SUT. The key difference across the two amps came from matching gains, Lee had bought his passive pre (will get details later) and we really needed to switch them to get the system to sound right with the AN to sound right as it was high gain.
later while listening with the Kondo chain again I realised these were excellent at low to loud mid volume, not fighting the room, totally coherent, great rise and fall, easy to listen to.
Lee’s audio note in future will make a trip to Bill’s place to continue the compare chain.
system was set up by Kevin Scott of living voice and was battery powered
View attachment 104119View attachment 104120
Speaker had Vitavox S2 driver and 12 inch Vitavox woofer. JBL 2405 tweeter and Vitavox super tweeter
