WOW - I can't recall hearing a better reproduction of strings - EVER...
Compare and contrast:WOW - I can't recall hearing a better reproduction of strings - EVER...
This does sound absolutely fantastic. I hope to pay a visit to Jean in the coming months, maybe he can lead me here...
Hi - the difference for me is significant. @bonzo75 VID sounds like I'm at the venue where the strings are playing. The VID you posted sounds like I'm listening to a VERY GOOD horn setup but doesn't present the same "you are there" magic - at least to me. I am sure others will have differing thoughts based on their hearing & perception.
I happen to find this a somewhat unfair comparison on the basis of these two recordings - knowing both, the one in my experience does have that "you are there" magic, the other, not quite. But I must say the combination of front-loaded bass and multi-cell horn does sound surprisingly transition-less, I'm impressed.Hi - the difference for me is significant. @bonzo75 VID sounds like I'm at the venue where the strings are playing. The VID you posted sounds like I'm listening to a VERY GOOD horn setup but doesn't present the same "you are there" magic - at least to me. I am sure others will have differing thoughts based on their hearing & perception.
Greetings from Switzerland, David.
Anyone have any experience with the Wyetech Labs Ruby XR300b? I have it in house currently and was wondering if there are any tube upgrade experiences to share. It goes without saying that these monoblocks are leagues better than my Line Magnetic 508ia.
All the Altec talk is getting my juices flowing.
These came in the mail last week.
View attachment 123446View attachment 123447
I still haven't had time to remove them from their crates, but here's a sneak peak.
The perceived “venue” is due to the lack of high frequency extension & resolution coupled with the bloated bass.
I think that becomes more evident in this compare and contrast:
Battle for Stalingrad
One needs to consider if one wants to listen to the microphone-feed or a curtailed rendition. The issue is that while the “venue” sound might complement classical music, how will those deficiencies play across different genres?
What are in your opinion sonically the advantages and disadvantages of the vents? To me these sealed cabinets sound particularly clean given the drivers are playing fairly high, so there's quite a bit of delayed midrange grunge with the traditional vented cabinets, a major pet peeve of mine that admittedly shows more on some music (solo piano) than other.My biggest raison d’etre for dual FLH is transition less ness, whether with multi cells or otherwise. With Altec 817 the standard crossover point and matching of drivers just works, so it is the crossover to get right while with other dual FLH like the ones Leif made you have to match drivers well and play with your cross point more.
the difference between Misho’s and this is that Misho’s was standard 817 plan, while this guy made his own design bass horn that is quite wide. 1.2m and it does not have the vents. He also made his own multi cells. The bass horn is sand filled. Sonically they are close.
I wonder how the frequency curve looks like on this Altec system
for once I tend to agree with Carlos
good can be anything from flat to 10db fall from 1-20K, as long as it´s even
sounds more like the latter due to tonal balance
