SET amp owners thread
you could add SETs then.
Pity that MBL ball is very hard to drive.
i heard the 116f are very easy to drive. Maybe get those and a SET so you can be part of both worlds
I am not using the MBL speakers much these days, the Statements are better on most of the music i play, the MBL amps sound great on them. I could use a second set of MBL amps on the sub towers, but i don't have a bag with an extra € 100 K lying around these days :rolleyes: Good news is i have dropped my Io Eclipse of for repair this week, only took me 1.5 years. I am looking forward to hearing it on the Statements.:)
I will get a system with SET and appropriate speakers for above my garage at some point. I have a 5m x 10m room up there i only use for storing boxes.
the FLH JBLs have 1KW at their disposal each and the subs 2KW, so never out of steam
I can connect my sub-tower to 2,4 or 8 ohm taps, have only used the 8 ohm taps, 2 ohm should be louder if the amps can handle it. I only use about half the gain on the crossover on the 8 ohm tap. I should experiment with it, but i hate changing crossover gain when i have found the right setting. Those dials are not marked very well and the tiniest movement can mess up the setting.:confused:
I am submitting an offer on a home tomorrow. If I get it, it has a 2 car garage with 10 foot ceilings Inwill convert to a mediq room. I would happily insert a horn of this scale.
Maybe then people will fly to Seattle to visit you first.
Reactions: Multiway
I keep my fingers crossed for you :cool:
How would you rate them still today?
Very high - brass/piano downwards they are brilliant, might have to reassess them for highs like violin and female vocals or get them tweaked for that range.
Reactions: christoph
Please do.
Does he still have them anyways?
Reactions: Lagonda
I put my horn back in. PAP Trio 15. I also have the coax. I got my absorption set up at the first reflection with the new door.
What I noticed is the horn does beam when I turn it up. Its like its trying to hard to present mass and energy. The coax with a 10" and a horn tweeter in the center presents with more body and weight. Makes sense. It doea make me scratch my head on how horns in general present energy to a listening space with such a small diaphragm moving air.
