I found the WAVAC HD805 to sound pretty amazing.
A consistently more musical sounding valve imho
the tube is cheap, but the rest of the amp is not. Mostly you need really high voltage to let that tube sing (maybe an interstage coupling is necessary) main transformer, choke, interstage transformer, and output transformer. that can get really expensive...ouchGM 70 is an inexpensive tube. For 300b if you stick to WE reissues and Takatsuki or Elrog you are fine, danger is in chasing old WE which really very few people do. 2a3 you will rarely find AVVT, you might find Fivre at 3k but otherwise stick to inexpensive tubes. But they don’t give much power.
There are very low watt tubes which can be inexpensive. But not many speakers those amps can drive.
So to get into sets, like with turntables is fun and good sound but if you are new to it just like you will try different carts and phonos and such, you should embrace the hobby of trying different tubes and topologies and parts.
A good driver tube for GM70 is the 6N6p…no need for an interstage transformer. But it has to be very robust overall amp to deal with high voltages…I think my Amplifon ran at 1300 or even 1400V but it made a true 40 watts Class A1 from one tube.the tube is cheap, but the rest of the amp is not. Mostly you need really high voltage to let that tube sing (maybe an interstage coupling is necessary) main transformer, choke, interstage transformer, and output transformer. that can get really expensive...ouch
Good exsample for not so expensive
I find this is where some manufacturer’s cut costs , if you are going to design a circuit incorporating IT’s then it is imperative that it is of similar or same quality as the OPT .A good driver tube for GM70 is the 6N6p…no need for an interstage transformer. But it has to be very robust overall amp to deal with high voltages…I think my Amplifon ran at 1300 or even 1400V but it made a true 40 watts Class A1 from one tube.
I bought four NOS military spec GE 211’s from Billington Export Ltd. UK for £325.00 each~ 800-1000$ a pair GE Nos tubes that psvane in the thivian cost 89$ one tube
Have you heard the older tango ones? I have 300b with old tango transformer and i think it sound quite good..No, Wavac 833s don’t sound good even when high power is needed. A friend used to have four piece Wavac 833s and replaced it with Ongaku. I heard Wavac 833s various times. IMHO there is no hope for 833 tube or Wavac amplifiers except the ones with old Tango transformers period.
The 6bl7 is a good driver for that voltage monster, you can build 2 watt se amp with that tube...that kick the gm 70 in the grid(ass)A good driver tube for GM70 is the 6N6p…no need for an interstage transformer. But it has to be very robust overall amp to deal with high voltages…I think my Amplifon ran at 1300 or even 1400V but it made a true 40 watts Class A1 from one tube.
Yes I heard them. IME 300B with old Tango transformers is one of the two great sounding Wavacs, other is stereo 805.Have you heard the older tango ones? I have 300b with old tango transformer and i think it sound quite good..
The trick is to direct couple to the grid of any power triode if you really want to see what it can do.The 6bl7 is a good driver for that voltage monster, you can build 2 watt se amp with that tube...that kick the gm 70 in the grid(ass)
SET power is the most expensive kind of audio power available...It almost sounds like being part of the SET club requires engineering skills. That or very deep pockets.
Cost per watt is a very poor metric to use compare to absolute cost.SET power is the most expensive kind of audio power available...
Not sure what this is supposed to mean.Cost per watt is a very poor metric to use compare to absolute cost.
The tubes are out.of reach.
The iron is expensive.
The speaker in finicky to the amp.
It seems like a guessing game. I'm pretty bitter I have close to $20k into my 845 and its not very good. Then I ask about 211 and told good tubes are unobtanium. I don't want that hastle. I want a readily available tube at a cost of say $1000 to retube the amp. And the tubes should last 3000 to 5000 hours. Thats why I got the Blade. Its darn reliable to readily available quality tubes that cost about $600 to retube.
Since there are PP amps and class D amps out there now that compete with SETs on any metric an audiophile might find important, then the cost certainly comes into play.
There are several problems you or anyone playing with SETs has to face.The tubes are out.of reach.
That still doesn't quite make sense to me. But if I take the example you state right here, it sounds like SETs are the most expensive kind of amplifier power based on weight vs output power, which IME is mostly correct. Tube amps have always been expensive power, which is why there were so many horn speakers in the old days when tubes were the only game in town. I think, generally speaking, that the metrics aren't important; Watt for Watt, SETs are the most expensive kind of amp you can own; for how much weight the amp has vs output power this is generally true too. If we talk about which are the good stuff when it comes to the power tubes, the SETs are still more expensive.Cost does but on the right metrics. Kind of like saying your amplifier is the most expensive amp per pound (lb.) of transformer
My example was an analogy of yoursThat still doesn't quite make sense to me. But if I take the example you state right here,
