Hi Ked, I use NOS RCA 2A3's, sadly not monoplates, though I have been in touch with Kevin about the set he has for sale and hope to have them here soon. David
Are you in the UK?
Typing error, thanks for the correctionActually its 3dB, since adding a 2nd tube in parallel only doubles power.
Hi Joao, I do understand that I'll lose 50% or more of the power, however I have tried the speakers with a pair of 45 amps I have in store that deliver maybe 1.75w and they were fine except for an earth hum which stopped me doing a proper longer term test. I must dig them out again to try and sort them out as that would show me once and for all whether either a 50 or a single 2A3 will work for me. David
Hi Ian,
I'm interested to hear that you are driving your Tonian's with a 35w SET, what size is your room? I have a silver wired pair of Ocellia Grandis Signature 30 which uses the same full range driver but different tweeters. At the moment I'm driving them with a PSE 2A3 amp which makes perhaps 6w and have been thinking of changing to a still lower powered SET, either a single 2A3 or maybe a 50. I don't lack for bass or volume in my 16'x23' room, indeed my preamp volume control is rarely past 10 o-clock, hence the thoughts about lower power. Have you tried your speakers with any lower powered amps and, if you have, could you tell me what you feel the extra power has given. Many thanks for your thoughts.
David
Joao,
Many thanks for the reminder. I hadn't seen the "hum pot" on the 45 amps as it is well hidden at the back and looks like a bolt to hold on the power transformer. Having now located it after your post I will reinstall them and have a listen. I have been plagued by other mains noise recently so had just put them back in the cupboard for another day. I'll try to get them set up next week.
David
Sorry for the very late responseSpeakers?
Speakers are Tune Audio Anima, Cube Audio Magus and Nenuphar, FinkTeam Borg and Boenicke W8 at the moment....
Preamp is now also Bespoke Silver version.
Hi BonzoSo you still have the Allnic 7000 phono, and what amps are you using on the Anima?
