You should give Qobuz a tryThe first one is Spotify and the second one is vinyl.
I plan on trying that and Tidal.You should give Qobuz a try![]()
Pretty big difference... what is your DAC?The first one is Spotify and the second one is vinyl.
Audio Note UK DAC 0.1xPretty big difference... what is your DAC?
My digital front-end is pretty modest because I usually just listen to vinyl.
I don't think Qobuz is available in Canada just yet. I get that message when I go to their site.You should give Qobuz a try![]()
That's a shameI don't think Qobuz is available in Canada just yet. I get that message when I go to their site.
Well, part of the country isThat's a shame
Firstly because Q sounds better than T (imho) and secondly Q is a french company and Canada is sort of demi-français, n'est-ce pas?![]()
Imagine every ex-girlfriend that has ever broke your heart, but you can't get over; that's the Toronto Maple Leafs. 53 years and counting since our last Cup. In a city where hockey is a religion.Well, part of the country is
It's complicated. Some of us feel closer to Britain, some closer to America, some closer to continental Europe, and we are a country of immigrants.
Somehow it all kind of works out. #go Leafs go
Yes, that was quite something. We had 2 million people out for the parade!Maple Leafs?
Like Toronto Maple Leafs?
No Stanley Cups for Canadian Teams for quite some time now, but instead the Roptors grabbed the NBA title last year![]()
I sent a picture and a description of my set up to the manufacturer and they confirmed that this is basically how they like to set up the 33s in terms of distance between speakers and toe-in. (I've actually increased the toe-in such that the drivers are directly facing me now).With horns, being quite a bit more directional, toe-in is very important. With my panels in the past I would have them nearly straight ahead. Horns...nope it loses focus and jump (at least with my speakers).
I am using a pair of Wall Audio M50 monoblock SETs driving a pair of Tonian Labs Classic 12.1S. That speaker is a 16ohm 96db basically single driver, a PHY audio silver wound coil driver run full range augmented by a Tonian ribbon super tweeter. It's part of a second system where my Lampi GA TRP is right now. Eventually (when I move to bigger quarters) my two systems will be combined. That way I can listen to huge powerful SS driving Hansen speakers or the SET set-up. I have a LDMS server on the way based upon recommendations of a number of Lampi users on this board.
Ian
Hi Ian,
I'm interested to hear that you are driving your Tonian's with a 35w SET, what size is your room? I have a silver wired pair of Ocellia Grandis Signature 30 which uses the same full range driver but different tweeters. At the moment I'm driving them with a PSE 2A3 amp which makes perhaps 6w and have been thinking of changing to a still lower powered SET, either a single 2A3 or maybe a 50. I don't lack for bass or volume in my 16'x23' room, indeed my preamp volume control is rarely past 10 o-clock, hence the thoughts about lower power. Have you tried your speakers with any lower powered amps and, if you have, could you tell me what you feel the extra power has given. Many thanks for your thoughts.
David
Actually its 3dB, since adding a 2nd tube in parallel only doubles power.you're loosing 6dB in power when using a single 2A3 instead of PSE.
