This is a long winded question, but I have more variables than equations (frustrating for a retired engineer) and need advice.
I have a Denali 6000 (V2) that provides power to a D’Agostino preamp, and a dCS Vivaldi stack (DAC, clock, upsampler). I also have a Denali 2000T that powers a pair of D’Agostino Momentum 300 amps. The 2 power conditioners are connected to a dedicated 20 amp line by Stealth Dream V10 (wall) cables. Details on the current power cord loom follow:
Wall to Shunyata 6000V2. Stealth Dream V10 (wall)
Shunyata 6000V2 to preamp. Stealth Dream V18 (pre)
Shunyata 6000V2 to DAC. Stealth Dream V12 (digital)
Shunyata 6000V2 to Clock. Stealth Dream V18 (digital)
Shunyata 6000V2 to Upsampler. Stealth Dream V10 (preamp)
Shunyata 6000V2 to Macmini. Shunyata Venom 14 (digital)
Wall to Shunyata 2000T. Stealth Dream V10 (wall)
Shunyata 2000T to amps. Stealth Dream V10 (power) (x2)
There are 2 open outlets on the 6000 V2 (I’d have to run an extension cord for the Macmini, but that’s not a problem). I’m thinking about upgrading the cord from the wall to the 6000 V2 to a Shunyata Omega XC, and using the 6000 (V2) for the amps, preamp, and DCS digital components (ditch the 2000T). That would fill all the outlets on the 6000 (V2).
To lessen the load on the 6000 V2, I could use a freed up outlet on the 20 amp line for direct connection of the preamp to the wall (D’Agostino recommends none of their products be plugged into power conditioners). Longer range, I’ll probably have another dedicated 20 amp line run to the stereo for the mono amps as well.
I can only swing one Omega XC cable now, and if I don’t need the 2000T (and the power cord that runs it from the wall) it’d reduce the clutter in my rack, and lessen the component/cable total.
Would I be losing anything by running the amps/preamp/digital components from the 6000 (V2) with an Omega XC feeding it, or should I leave the amps on the 2000T?
My intuition is it’d be an overall improvement. From what I gather, the 6000 V2 is non-current limiting and can handle the combined component load (won’t choke off the mono amps) and replacing the Stealth V10 (wall) cord that feeds it with an Omega XC would be a sizeable improvement.
I’ll complete a full profile of my system soon, but for reference here are some photos.
