The everest is awesome
Sounds like we have the same ideas and goals regarding keeping the power cord family the same by using the latest from Shunyata.I also made an order for some new power cables. My previous ARC Ref 160m amps required 20amp cable termination, the incoming Pilium Achilles amp requires a pair of normal 15amp cables. Previously these were Sigma v1, now to be v2. I also am upgrading my cable feeding the Triton from the wall to a Sigma XC, where this was a Sigma analog. I had a couple Alpha NR cables delivery current to my ARC Ref10 preamp (again a 20amp receptacle), and my dCS Rossini DAC, these are being upgraded to Alpha NR v2.
I had been using an older Python to feed the turntable power supply, and another for the CS Port phono stage, but the CS Port is battery driven. So for those two I chose a couple Venom NR cables with a little extra length—and the flexibility will be a plus.
Since I‘m changing so much of my rig, I decided to stay with Shunyata power because I like and appreciate their products and approach. I am, similarly, staying with my Transparent signal and speaker cables, though I did send the interconnects between the pre and power amp, and the speaker cables in for recalibration.
its been a very long time… sadly no recollection.…
I have been contemplating upgrading my turntable power supply to either the Venom NR V10 or the Venom V14 digital. Did you notice any changes when you started using the Python?
My power supply is this: http://www.solidstate-audio.com/index.php?main_page=product_info&products_id=6913
It is a regulated power supply and speed controller.
That is okay…the addition of all of the other power cables will more than likely be a breathtaking experience.its been a very long time… sadly no recollection.
This one’s best left to Shunyata to answer. As best as I can determine the Omega interconnects add the Transverse Axial Polarizer (TAP) feature to the CMODE on the cables. But the Omega moniker may simply be just a label - nothing more. Maybe at some point a new upper echelon called Omega, or something else will emerge. So, with TAP already on Sigma analogue interconnects the missing piece, if deemed viable, would be CMODE. I‘m not technically knowledgeable to say if that is necessary for analog signals…
Does anyone knows if will be released the Omega analogue interconnect any time soon?
Here’s one of the patents that covers QR/BB: https://patents.google.com/patent/US10031536B2/en?oq=10,031,536It will be interesting to see if an Omega flagship line makes its way to analog interconnects and speaker cables.
If so, my guess is that their QR/BB tech could perhaps be applied these cables. Which would be the main difference over Sigma V2.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
