mbovaird Banned Jan 5, 2013 146 1 0 Nov 19, 2013 #1 I would like to hear from some of the Wilson Alexia owners on what you recommend for speaker cables.
Bruce B WBF Founding Member, Pro Audio Production Member Apr 25, 2010 7,084 650 1,740 Snohomish, WA www.pugetsoundstudios.com Nov 19, 2013 #2 well I did try the Transparent Opus MM2 and didn't care for them. The biggest revelation was when I put my old cables back in that I noticed the difference. JPS Labs Aluminata. I wanted to like them. Maybe the Ref XL would have been a better fit?
M microstrip VIP/Donor May 30, 2010 21,679 5,315 2,890 Portugal Nov 19, 2013 #3 Bruce B said: (...) Maybe the Ref XL would have been a better fit? Click to expand... It is what I am using with success. But I would not mind trying the OPUS MM2 ...
still-one VIP/Donor Aug 6, 2012 1,692 203 1,220 Milford, Michigan Nov 19, 2013 #4 microstrip said: It is what I am using with success. But I would not mind trying the OPUS MM2 ... Click to expand... Opus SC work very nicely with my set-up. I am staying with Ref IC's until I determine whether I will add the Momentum pre-amp to my system.
