Stereophile | January 2017 Issue
Let me congratulate all participants of this thread for the high level of discussion.
I learn a lot from it .
The post of Stavros is absolutely key for me and explains what I experience with my setup for last 6 years.
I hear less compression and more palpable music with highly effective speakers ( 109 db) driven by rellatively small power SET amp( 30 Watt per channel)
I would also point out that the very important factor is the gain of the source in the chain, for example my Lampi is very easy load for the amp and thanks to that the amp operates at very low power with fair SPL.
Selection of the right amp is also -or maybe mainly - taking in consideration the synergy of the setup.
From the other hand the Einstein The Amp Ultimate (OTL) sounded best for me from above 10 different amps I tried as far as the coherency, timbral accuracy, dynamics and other audiphile criteria are concerned but had to much gain for my setup and I couldn't listen to it more than 20 minuts.
I share also the experience that some of more powerful SS designs had less authority and slamm than weak SET's , and interistingly- it concerned mainly low and mid bass.
So you chose the Crossfire over the Einstein?
Compression of low sensitivity drivers actually sets in well before they have reached their power handling capacity. You get both thermal compression and dynamic compression effects.
One thing a lot of people don't talk about though is at the other end of the loudness spectrum... the quiet end. It's down at that end that another kind of compression occurs. Specifically, soft sounds simply don't get efficiently transformed into cone motion. The signal comes through and the cone does not respond or responds inadequately to the signal magnitude.
This is due to electrical inefficiency and simple mechanical resistance to motion from relative rest. I heard this with a number of insensitive speakers where they really fall apart at low volume and coupled with a compressed high volume end means that their overall dynamic range where they perform well is narrow.
An exception I have heard to this is electrostats where they do soft very well and so are only limited at one end (loud) of the dynamic range spectrum. They sound less compressed than boxes of similar sensitivity but less than horns.
Spot on!!
In my setup , yes.
I heard once Acapellas which are much less effective driven by an Einstein and it was for me best of show( Munich 2014).
Synergy rules:)
It is not just the voice coil heat up or the Xmax limitations.These were only an example of how far apart can two transducers be in their effectiveness converting electrical energy to acoustic energy.
That is why i said even a tiny 2W would beat a welder-spec amplifier if the latter drove X and the former Y.
You chose not just _any_ tiny 2W amp though, you specifically chose one with puny power supply capacitance. Such amps tend to be SE classA in operation right? Or am I missing something important?
Hi
No,it is just to emphasize that a small amp with no special energy reserves can sound more dynamic paired with a right speaker,than a SS with a wrong speaker.
Big SS can and some have great energy reserves,and their energy reserves are not the reason why lower efficiency speakers sound more compressed(which was you initial comment).That is the reason i emphasize it.
Of course big SS does not always equate dynamic sound with high efficiency speakers,but this is another topic :)
A SE amp is by definition Class A.
Now this isn't clear to me, what 'no' means. Is it an answer to my question 'am I missing something important?'. Or its to deny that you chose a specific kind of 2W amp?
I agree that energy reserves are not necessarily relevant to how dynamic an amp sounds so I'm curious about the kind of 2W amp you introduced in your illustration.
I agree that an SE amp is by definition classA incidentally. I should have written them in the opposite order 'classA, SE'.
When did I mention 'energy reserves' in my initial comment? My memory's not as good as it used to be, but I don't remember mentioning them at all. Energy reserves only matter indirectly in my experience, what's more important is the impedance of the PSU over frequency (this tends to have fairly high correlation with energy reserves), and even that's not as important with certain kinds of amplifiers.
....... Its a widely appreciated observation that high efficiency speakers sound more dynamic than low efficiency ones, I put this down to the difficulty of building high powered amps with the highest level of dynamics. That in turn stems from the physical/electrical limitations of capacitors which are the primary power source in practically all amps.
Hello opus
Sorry for the hasty answers ...a bit busy with expanding the premises and i have to be on top of things....
The "No" is to deny that i mentioned any specific 2W amplifier,i had to be more clear maybe....
So,your comment above implied that low efficiency speakers somehow lacked the dynamics of high eff speakers because of the lack on rock solid energy reserves from big power amplifiers that drive them.If i read your comment correctly.
All this back and forth is to show that this is not the case. I chose the two extremes in amplifiers, big SS with massive energy reserves(high capacitance,low ESR and ESL cap banks),and a puny SE 2W amplifier to the other spectrum for my example to emphasize that this is not the case,low efficiency will sound more compressed due their drivers and not because there are not good enough PSUs in current amplifier technology.Speakers is the main contributor to compressed sound.
Cheers
Stavros
No worries Stavros, we all have our various constraints on participation. I wasn't asking whether your 2W 'puny capacitance' amp was a particular one, rather whether it had certain identifiable characteristics, the most important of which to me would be whether it was an SE amp. If it was - and you do seem to confirm that's the case later down the post - then capacitance is largely irrelevant for that particular topology of amp. Which I'd say has a fighting chance for being the reason the designer didn't see fit to include a lot - with SE amps, more capacitance (and hence more energy storage) doesn't lead to superior dynamics.
The part of my post that you bolded (thanks for highlighting which of my words you're arguing against, it makes responding so much simpler!) was in the context of high powered amps. High powered amps can't in general afford to be SE because that topology is rather inefficient, even when designed for a specific load impedance. So historically high powered amps have tended to be classAB and its this kind of amp which places extreme demands on the PSU. Its classAB amps that tend to be called for with less efficient speakers and its my hypothesis that the lack of subjective dynamics is down to the amps being noisy, not primarily down to the efficiency of the driver(s).
So it seems to me you've been tilting somewhat at windmills in your response - my argument has not been about the necessity for rock solid energy reserves, rather the need for low impedance power supplies to feed higher powered, typically classAB amplifiers.
Does any of that help to clarify? We're still at disagreement over whether its primarily speakers or amps that are the major contributor to compressed sound but hopefully we can disagree for the right reasons. I'd be interested in the results if you swapped your SE 2W amp for a 2W classAB chipamp (add plenty of supply capacitance to taste) to see how good the dynamics of your horn turn out to be in this particular case.
Hi
The example's horn will convert 50% of it's input energy into acoustic energy,where as the typical midwoofer would struggle at 0.4% (not a typo).
You cannot expect a driver to receive 125 times the energy,and behave as linear.Unfortunately there is no way around it.And i say unfortunately, because it would be nice to have an alternative to a half a tonne midbass horn.....but when you hear one,there is no going back:)
I am enthralled by these two posts...they are incredibly clear, make a lot of sense. And I have to say, REALLY now intrigue me in regards to [well] designed horns. I have heard some and been underwhelmed. (i have posted those thought in this Forum but will NOT rename them to avoid distracting from my main message). In particular, i am most intrigued by the half-ton mid bass horn comment and the description of horn and cone technical characteristics.
I categorically wish to avoid a horn v cone debate. (I also stating up front I am aware that Aries Cerat has a gigantic mid-bass horn in their Contendo Reference speaker which i have always wanted to hear...and i wish to avoid any discussions about manufacturers being biased, or pushing their 'agenda'...and stay on target for a few questions from STAVROS, MORRICAB, or ANYONE who is happy to provide technical guidance in regards to a few questions on horns:
1. THERE MUST BE SOME DISPERSION, POWER AND LOUDNESS MATH OF 'SOME AMOUNT' THAT RELATES TO HORNS AT THE MID BASS AND LOWER BASS LEVELS. Most of the major horn companies that are going for full-range and full-dynamic capability have bass horns that are absolutely immense. Is it simply that to get a horn to generate deep bass at 115-120db peaks (kettle drums, deep house music, etc), this math basically forces the horn to be gigantic? (ie, flip side is that the reason we see cones in subwoofers, bass towers is because the equivalent horn or panel would be way too large for a domestic environment?)
2. Does the sheer size of the horn effectively allow for a kind of 'non-electric' form of amplification of the original bass being generated somewhere behind the gigantic horn? Is that the 'simple man's' physics behind how the horn generates loud, powerful bass?
3. Do gigantic horns for bass suffer from major vibration issues like cones (subwoofers, woofer towers...even the internal vibrations from full range speakers can cause internal design challenges to the attached mid/upper frequency cones). Is it the cone movement that causes these vibrations...or the power of the actual bass waves themselves?
4. WITHOUT getting into 'i am better, or you are not' fighting, i would like to ask about the challenges inherent in cone bass being blended with horn bass. In an ideal world with NO PRACTICAL CONSIDERATIONS, does a designer of horn speakers ALWAYS seek to have horn bass? (again, NO practical considerations whatsoever).
5. Are there mathematical and physical differences in the way that horns generate deep bass (vs cones) such that those little differences ultimately create dischordance between the quality of sound at the mid/upper levels vs the deep bass levels in an ideal design?
It is not my Se amp or anyone's,it was "just a 2W amplifier" to make the point given...Anyhow....
And yes SE topology does like high quality capacitor banks.Who ever said the opposite?
It never said anything about Se vs SS,class A or class AB,nobody mentioned this so far... my point is that the amplifier's PSU and amplifier in general does not have anything to do with the superiority of HE vs LE speakers over dynamics.So no windmills,my posts were clear from the beginning on what i was arguing about.
Rock solid energy reserves(high capacitance,low ESR/ESL) is another phrase for Low impedance power supplies.
I do not see any windmills,again, i only see trouble in understanding the basics before going further.
I see that you have taken the hypothetical 2W amp,used in my example ,that it is somehow my reference,and that i do like low capacitance...How did you ever came to this conclusion?Who said the the mentioned horn performs the best with the example's 2W amp?Is my english that bad?:)
Again,i said,that a high efficiency horn,ANY horn,with ANY small power amplifier,will outperform ANY conventional low efficiency driver ,driven by a very high power amplifier,because of reason X or Y.From all this,all you did understand is that my reference for driving my horn is a 2W amplifier?
i think i will pass on anything AB,chip or not:) but thanks for the suggestion
Stavros
It's both the speaker and the amps that can contribute to a compressed sound. I have heard, in particular, Class AB amps with a lot of negative feedback sound compressed and unable to express dynamically.
Puny power supply capacitance...perfect
Non critical chokes.....perfect
Low DCR......perfect
Low gauge hookup wire.....perfect
Less than 2W ......perfect
There's more than one way to build a SE DHT amp.
Cheers
Blue58
We can start another thread,we already butchered this one:)
A horn is designed having a strict bandwidth to cover.A good rule of thumb is two-three octaves.The horn's cut off frequency is dictated by it's length and mouth area.A horn with cutoff of 100Hz will have double the length and double the mouth area of a 200Hz horn.So you can see it is the cut off frequency that dictates the size.
A horn is an acoustic transformer.Just like a mechanical transformer(gear box in your car) or electrical transformer,it changes the acoustic impedance that the driver that is loaded with.A direct effect of this is a very big increase in efficiency,but since there is no free meal,you loose directivity(a good thing in my opinion)
and loose bandwidth(for a specific horn).also a good thing.
Like all structures,metal,wooden or composite,everything vibrates.Bigger stuff seem to vibrate more:)But seriously,bigger structures are more difficult to brace correctly,to be made stiffer and have sub-critical dampening.Again weight picks up pretty fast when trying to solve these issues. So the horn construction is as critical as everything in speaker technology.And not only for bass horns but any horn.
Bass horns must be big,and are much more expensive to manufacture.It all boils down to what is the least compromise,in size,weight,cost.
The mathematical models for a particular horn flare type is the same,for all frequencies.What is world apart,is their implementation... for example how an actual midrange horn can be constructed closer to the ideal shape with proper materials,where as the bigger the horn,the more you deviate from the ideal.
Cheers
A little bit of some of them ... Your system is so finely and precised tuned as an whole that no amplifier will have a fair opportunity against the NH458. Particularly IMHO it would be very difficult to change electronics keeping the balance you achieved between speakers, tape, vinyl and digital.
There are some aspects that also IMHO are unique to the NH458 - an equilibrium of continuousness, sweetness and authority, but keeping the texture of life music. Some systems will not show it, but I am sure you understand what I mean.
thank you Micro, for the kind words.
and yes, I understand completely. we all search for the right strategic pieces in our systems which end up giving us more and more musical goodness as we unleash it from the bonds of system discontinuities. the 458's continue to show me more and more musical truth with each layer of restriction I remove system wide. optimizing any amplifier is never trivial. personally I do think the 458's particular combination of attributes is unique and is quite amazing to enjoy every day. I never take the 458's for granted.
It's fairly well known that classA amps are very transformer dependent. Everyone whom builds Nelson Pass's Firstwatt designs swears a larger transformer sounds better, but increase the capacitor bank doesn't appear to do the same thing. It's not surprise, and historically consistent, that tube amps in classA don't seem to respond to massive capacitor banks either.
And how are dynamics defined? For me it's changes in volume. Sometimes they these changes have huge differences in crest factor, requiring lots of power to be 100%, and others simply do not. Often what sounds loud and powerful to us, simply is not, in terms of power. Now different speaker loads might change that factor where the amp is now asked to produce a lot more current, but usually this isn't the case with high sensitivity speakers.
So I'm sure the SE he prefers doesn't ultimately have the highest crest factor capability, but it sounds dynamic. The very impression of it gives you the idea there's power there not because of wattage, but representing the power in the music. In order to achieve this with electronics it has more to do with what I like to describe as 'current being in phase'. That's not exactly what's happening, but the description is easy to understand. SE tube amps may have an easier time achieving that goal. For example they can use all film caps so the values of capacitance and inductance are less at odds with each other since they're closer and less likely to sink current. But the real trick if figuring out how to get more capacitance in without the drawback, so you've got it all.
Not all classA amps are SE, and there's an even smaller subset of SE amps which I reckon are insensitive to power supply noise - they're ones I call 'power supply invariant classA'. I've looked at a few of Nelson's published schematics and not noticed any which fall into this last category.
I don't have a definition - its all subjective. Suffice to say I know it when I hear it. 'Jump factor' would be another way to talk about dynamics, the ability of music to trigger my startle reflex is a sign I'm getting good dynamics.
I'm not sure I'd call ripple noise, sure, technically, but I call it ripple for a reason. If you mean what the cap banks should capture, well, I don't think they do much of that honestly until you do something like your CLC.
Dynamics are always better with current in phase. The current must be as immediate as the voltage signal. Sometimes this happens easily, sometimes it's luck, sometimes there's no hope! Sad fact o'life for most. It's the difference between the snaps of drums sounding dynamic with regular volume and no huge crest factor, and being flat waiting for a big crest. Most high end systems I hear will have one or two points in a song where the crest factor is so huge that despite the current problem, even coming in late, it's very loud and "dynamic"(ish) sounding. The problem for me is that as I've been saying drums should have snap whether someone is giving the god-thump or just gingerly going along. In fact I'll take underpowered amps that make 98% of the music sounded exciting vs ones that do it louder for 2%, if forced to choose (hopefully I'd just get more sensitive speakers). And yes, I think what I'm talking about is jump factor, but for the whole album not just 2%.
