BHE fad still raging. I heard jriver 256 upconversion feeding BHE in AO core mode and I remain stunned.
I expect HQP upconversion to BHE would be even better..though I dont know how..
Cant until i get back home and print out to really digest the info.
What I heard was far from fairy dust. Stunning stuff...one of the best demos ever...and you know i have heard some top notch setups.
Mike, I like your updated avatar image. Is that your little one?
Hi Blizzard,
May I ask: I use Mac/A+.
Is this streaming option path open for me too? Or is this basically working with HQP?
thanks for your insight.
Hey Blizz, how do you think this would compare? http://www.audiocircle.com/index.php?topic=139697.msg1488798;topicseen#new
Buzzard,
It is great to see that you finally figured out a real common sense path to excellent sound. And it even uses USB!!!
I've read this thread and overall it is pretty good. The dual PC suggestion is an good one. Lots of us have been doing this for a while either with HQ player and an NAA or JPlay. I'm also glad to see that you've caught on are are using fiber.
If you look into the threads on CA some more you will also see some suggestions for fiber switches. When you get the chance give one a try also.
You may also want to try some of the less expensive linear supplies that people mentioned on eBay. They're not bad and will work well for the media converters or switches. Another suggestion for the converters would be these inexpensive linear supplies.
http://www.jameco.com/webapp/wcs/st...Id=10001&ddkey=http:StoreCatalogDrillDownView
For the transceivers for the converter you can also try these.
http://www.ebay.com/itm/201380389984?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
They are less expensive than the branded ones and also work well.
When discussing fiber people should be aware of the differences between single mode and multimode and be sure they purchase the properly matched transceivers and cable.
I also use single mode as theoretically there may be less jitter. I have not compared nor do I really think I might hear a difference between single vs multimode but YMMV.
Also have you thought about powering the NUC with a sealed lead acid battery? In the past I have powered an Atom CAPS with an SLA and a car stereo capacitor I had laying around, and thought it worked well. It is a pretty inexpensive way to get clean power that is off the grid. You also mention switching supplies and you thought that can be good. This is true to a point, but run of the mill switchers can put crap back into the AC lines, so even though they might sound ok they may pollute the rest of your system.
Why don't you just recommend using the 32 GB memory stick from Amazon. It is only a few dollars more than the 16 GB and you won't have to worry about image size anymore.
http://www.amazon.com/SanDisk-Ultra...1-fkmr1&keywords=SanDisk+Ultra+Fit™+CZ43+16GB
I am not a real fan of those flat Ethernet cables. You probably will not notice much of a difference for such a short cable, but I don't really think they truly meet spec. Why not use some good still inexpensive Cat7 cables like these.
http://www.amazon.com/Rosewill-Shie..._UL160_SR160,160_&refRID=1PBZDTR3ZTY0P25KXZ82
Have fun.
Bob
That's the Cubox-i that I was going to use at 1 point.
http://solid-run.com/freescale-imx6-family/cubox-i/
But I decided against it because the hardware isn't near as good as the Intel hardware, and it costs the same by the time you get it shipped all the way from Israel. As far as the Linux implementation, very similar. He uses the exact same airplay, and HQplayer NAA daemon. Only it looks like you have to reboot and launch into a different mode to toggle between HQplayer NAA and airplay. Not sure if you need to hook up a monitor for that or what. Mine is automatic and seamless.
However if someone really wanted the Cubox, I could easily make it work. All the other features like MPD, DLNA etc, are only a click away from enabling as well. I chose not to do it because they are inferior ways to do things anyways.
What makes you say that Cubox is inferior to NUC?
For that product, there is no need to reboot to select different mode. It has built in web server such that you can use the browser to select different mode.
The reason I chose the Intel product over the Cubox product is the same reason I already said. It's simply not the same level of quality as the genuine Intel products. Not only that, you must order it from Israel and wait a few weeks instead in 2 day prime with Amazon. Of course theres several more reasons the Intel boards are better like the 68000 hour MTBF under 50c conditions. Look at the user manual for many more.
As far as switching modes, I'm not sure how logging into a mobile web browser is more convenient than having to do absolutely nothing besides closing HQplayer to enable AirPlay? Close HQ player and AirPlay works. Stop the AirPlay, and HQplayer will work. No need to touch any setting.
It would take me 5 minutes to turn this into a Cubox product instead of an Intel NUC product, so if you want a Cubox version, let me know.
The mentioned product has more modes beside NAA and AirPlay. It can function as DNLA client, Roon Endpoint and Squeezebox client. This is useful for people who want to build multi endpoints in their home.
Thanks for your offer. Actually, I have a spare Cubox around. I may take up your offer.
Thanks for the suggestions:
-That supply is a piece of crap and I won't recommend it. Just because it says "linear" in the description, doesn't mean it's good. Not only that, the max amperage rating is right at the continuous rating of the FMC. That's just asking for trouble. If you are going to settle for a cheap wall wart, I'd recommend at least going with a 10 W supply minimum.
-Same with the transceiver, just because it's the world's cheapest transceiver, doesn't mean I'll recommend it.
-I've given a clear parts list on what to buy as far as FMC and everything else.
-As far as battery power, It is better than using a cheap SMPS, but not as good as a supply like the Teddy Pardo. Also more equipment rack friendly.
-The 16GB stick is a non issue now as the image size has been reduced as documented.
-I've found the flat Ethernet cables to work fine with my testing, not sure where you came up with the idea they don't meet spec. Are you pulling this out of the air to try to make the post longer?
Thanks for the feedback.
That 9V supply works fine and it is basically rated the same as the one shipped with the converter. Did not say it is equal to a $500 supply. Maybe try it before you say it is crap. You are posting a way to get good sound at a price and then you recommend $$$$ power supplies for $25 transceivers. There are other ways to power them. People are also using USB battery packs with good results. People should read the CA threads.
If you actually understood who makes things like theses GBICS you might realize they are all pretty much the same. Why not just use OEM Cisco then if you think others may be substandard?
Have you actually compared batteries to other supplies?
Ethernet cables can make a difference. People should use better cables it is a no brainer.
Have you thought about the fact that the NUC you are recommending is only single core and if that can make a difference vs multi core, and assigning processes to their own separate cores?
You are obviously confusing the server that runs HQplayer with the NAA. The NAA end is capable of utilizing dual cores, but if it's only running at 1% CPU load anyways, using a multicore processor could even be detrimental due to additional noise.
