DoP maxes out at 128. So you'll have to wait for that update for 256.
No, I think Lukasz has it (Linux) working on 256 with DoP.
In order for 256 to work over DoP, the hardware must support 24/705 PCM. I thought the Amanero hardware maxed out at 24/384. Which is why it's called the combo384. You should double check with him.
That is what he told me yesterday. Perhaps he already has different firmware?
PiFi – How to Network your Mac music system with the Raspberry Pi and HiFiBerry – Part 1:
http://www.hifizine.com/2015/10/pif...m-with-the-raspberry-pi-and-hifiberry-part-1/
Blizz, after you got the whole process down with some trials, you need to make another topic only you post in. Reading 15 pages over the span of 2 days that's mostly you arguing with some dude is a mild form of torture.
Questions.
1. Can I install the OS in the unit, and how? Do I just do it on an SSD HD that the unit has room for? (2.5")
2. How do I eliminate the need for a computer server? I take it this unit won't run the player at the same time. Can I run it on a Raspberry PI, with an HD connected to it? Ideally the unit would just the player and the HD would be in it... Either way needing some computer somewhere with a lan cable is out the question for me.
3. Forgive my ignorance, I assume this player can be controlled with ones smartphone?
Blizz,
I want the OS installed just because I don't want the port occupied. It's just like how when I'm done with my soldering iron I like to put it away.
It's clear that this unit is a good way to go. But I don't understand what you're asking me to read over, I just read 15 pages. At no point was it made clear to me if there's options about using an SSD drive and running the player with the unit you're selling a USB loaded stick for. I've seen several setups that are simply a Rpi with an HD to a USB DSD converter. It's all in one, essentially.
There must be a way to remote control it, especially if the server can be, as you say, in the other room.
Blizz,
Thank you for the usb running Linux explanation. It is very assuring. However, is it the best if the NAA have a micro sd input to run Linux os, it will be the lowest noise possible?
This is very appealing as I learn. What about having a network HD, and running the player on the NUC?
