It's amazing that one would slam products simply because there are no published measurements. I would venture a guess that installation location, etc. has a large effect on the final result, whether the product is RAL-certified or not. From personal experience, I know I got different results when I placed my half-dozen ASC tube traps in different spots in my room, but they have measurements on their site. So, there are more requirements to be met than merely having measurements that show the effect of the devices under a single (or limited #) of circumstances.
Lee
Well, when tuning a room, typically AE. measure the room, then they figure out what product will improve that measurements. There is certain amount of subjectivity involved, but there is also some objectivity done as well. There are new products coming out all of the time, it just takes a while for people to know what works best in their room to solve their problems. But if you are just placing room treatment around a room and not taking measurements, it will take longer to get things right, unless you luck out the first time.
Most acoustic treatment I've seen does well for mid and high frequencies, but the low frequencies are the hardest. Plus, there are different points of view of what works best. Some think tube traps work, some like diffusors, foam (different brands available), etc. etc. There are also different room sizes and purposes for the room. Then there is different systems that will produce another set of circumstances where additional treatment may be needed. But in the end, Certified Acoustic Engineers use measurements and they will be more likely going to use a product that has been tested so they can look at the efficiency of the product.
either way, SR would be best to have their products tested by RAL, but they aren't known for making room treatment products, so they really aren't approaching this the same way that ASC, Acoustic Fields, Sonex, RPG, etc. would approach it. Unfortunately. it would resolve a lot of these discussions if they did.
