I am considering Thomas 10Y line and phono as well for sure.
HF or LF ones?Beautiful system! Who built the horn boxes for you?
Yes.. we talked in the phone. PBN also custom made my speakers as well. Congrats on the new speakers, I’m positive that the Fostex Super tweeter will be a great enhancement to your system.HF or LF ones?
Bass boxes were built by PBN Audio and multicellular horns by Markus Klug
I remember you told me about the Fostex. Peter of PBN is a great guyYes.. we talked in the phone. PBN also custom made my speakers as well. Congrats on the new speakers, I’m positive that the Fostex Super tweeter will be a great enhancement to your system.
Philadelphia areaMaril, if you don't mind, where are you located?
Thank you,I use those fostex tweeters in their mkII form in my own setup, I strongly recommend using them for over 10khz, they are great. They also respond very well to vacuum bypass caps in crossover.
Congratulations on the new amp and speakers. Could you describe your front end and preamplifier? I thought I saw a FirstWatt amplifier on the floor as well as a Pass Labs crossover on the rack.I am considering Thomas 10Y line and phono as well for sure.
Misho received a patent for this crossover did he not?
Awesome system. While you might change a cap here and there or a driver I would imagine this is end-game stuff![]()
Thanks. I first saw this on my phone and forgot there is no signature listed. I see it all now. Sorry.Shindo Giscours, from his signature. It also has a built in phono. My guess is the kiseki purple heart into Shindo will be a bit too warm and colored for my tastes, having heard both separately. That is the prized product from the Shindo line though.
Maril, Misho's phono at 4k euro direct is also brilliant and extremely flexible. he has a matching SUT included and you can just play any cart in it. The Altec sounds great with SPUs too, and I would be tempted to recommend vdh strad if you can source a good sample. It will add to the high frequency.
You have used Misho's crossover with Duelunds. He himself prefers older film caps. Most swear by Duelunds in speaker crossovers. Now that you have Duelunds, you can try the other one later as cost will be quite cheap.
Sure,Thanks. I first saw this on my phone and forgot there is no signature listed. I see it all now. Sorry.
Misho did make a transformer based x-over, and I discussed him making one for me, but it’s more complicated, than it seemed to me, as it requires a lot of in situ testing and re-winding, which he has no time for right now.yes but that crossover is later. If Maril sets his LPAD value, Misho makes a crossover where he has his hand wound transformer and no resistor. Silvercore's crossover for his speaker has a hand wound inductor that eliminates the capacitor. Since both are in the business of winding it is easy for them
