dc voltage can be easily filtered out of the mains it makes the transformers of devices hum or can lead to early loss of dynamics (saturation of the transformer) at high power.It was awhile back and I cannot recollect the other parameters. I only remember the ones I referenced. DC offset was the main target...
If it wasn't because of the insistence of the manufacturer that it was DC Off Set causing the issue I wouldn't have gone to such lengths to prove them wrong. I knew it wasn't a DC issue...dc voltage can be easily filtered out of the mains it makes the transformers of devices hum or can lead to early loss of dynamics (saturation of the transformer) at high power.
interference frequencies in the150 hz -3 khz range are difficult to deal with. standard mains filters are of little help there.
DCT03 DC filter for toroidal transformers - heavy duty version
A DC filter for in particular toroidal transformers. It works for any mains voltage. The pcb has two layers and gold pads. It's an unpopulated pcb. Info heresjostromaudio.net
Hi John,Totally system dependent IMHO. I also use NCF Rhodium outlets for the Gryphon Mephisto/Pandora which requires 2 power cables each and for the Horizon. For the Extreme all copper, both outlet and power cable. Copper for subwoofers. I know several knowledgeable members who hate Rhodium. Audioquest sent me 2 High Current Dragon power cables awhile back for the Mephisto, I hated all 300 hours of listening to them. Point being what ever sounds good to your ears...
It is difficult and time consuming, couldn't agree more. I have always tried to match the metallurgy between Power Cables and outlets.Hi John,
It is hard (at least for me) to compare outlets. After changing them it takes a while for the burn-in, so no A-B-A testing. So I would appreciate to hear Emile's recomendation for (in his oppinion) best brand/model of outlet.
Cheers,
VPN
another question;maybe a stupid one, but it´s very late here in Sween![]()
Every question has value, and I am aware of another ?????? switch that effectively enhances file quality when playing local files. It wouldn't be unexpected if the Taiko switch had a similar capability.Do the extreme switch + extreme network card alter the sound on local files (Flac,dsd, SACD an wav)
Technical datsThe type of DC blocker you refer puts electrolytic capacitors in series with the mains supply, increasing the mains impedance and distorting the mains - small electrolytic capacitors will not be able to supply the current peaks needed for more powerful amplifiers.
Hi, I am rescanning my library threw XDMS, but it's already like half a day that tanning is in progress, this is normal?
Thanks to share your experience
I would like to ask if taiko switch can work in 10Gigabit? If both upstream and downstream are in sfp+ 10G mode?intel X710 in nas and pc?
Dear Emile,
Thanks! Great information!
Regarding your question, "3) Do you use tilted up components like for example Furutech NCF Rhodium plugs or outlets, or Silver/Rhodium plated plugs / outlets from other companies?", which was not a question you made for me, but I happen to have many Furutech NCF Rhodium outlets and some power cables. What is your recommended outlet brand/model?
Cheers,
VPN
@Taiko Audio:Emile was Oldenzaal affected by the bad weather yesterday? Unreal, 90pmh winds in the summer...
Oli59, is all good after a scanner updateI see you’re on Discord, if you ask there you’d probably get a quick response and/or help. Alternatively you can contact support@taikoaudio.com .
