You are lucky people - as far as I know UK customs are very flexible with the CE electrical certification - they have always been training for the BREXIT ...![]()
You can buy UK goods cheap now
Robert Hartley about the The Berning 211/845 60W amplifier: I won’t mince words: The Berning 211/845 is the most beautiful sounding amplifier I’ve ever heard.
http://www.theabsolutesound.com/articles/?products=3048
Harley's review was very well done I thought.
Microstrip, thanks for the link.
We can't ignore the context: Let's not forget that for the better part of the last decade Harley has been telling us how Soulution/ Constellation is the best there is. Same pattern as when Valin moved from Magico Q5 to the more euphonic Raidho after spending a long time with that speaker.
Something better more beautiful comes along . If you sampled as many wares as he does , similar proclamations would likely arise .
Gentlemen, does anyone understand how the ZOTL is different than a regular OTL, such as the fabulous Atma-sphere?
I agree it is some of Harley's better work, but would have been much better if he compared it to similar products. He ends up using Valin's quote pertaining to VAC. Without understanding relative differences between components, one can then generalize these conclusions to all tube amps...
I have to disagree on this one. I have no significant experience with the 458, but I own the 108 and have owned the 8550 and the old 18NS. IMHO some (and much more than just a few) tube amplifiers are equal or even better than these two models in recreating a large real 3D image with true ultra low level true cues, with large orchestras and complex music, with plenty of high frequency extension. IMHO we must avoid generalizations using words such as "most" when comparing to our preferred brands.
Having 'the best' of both (i.e. solid state and tube) worlds, that is audio nirvana. Do I understand you correctly you are aiming at top solid state and tube amplification to combine with one set of loudspeakers?
The Berning ZOTL amplifiers are not simple circuits and the signal path is not simple! They are very complex, using RF conversion transformers to avoid the need for a large output transformer. It is why some people object to call them OTLs. Please see the patent that generically describes the circuit https://www.google.com/patents/US5612646.
And yes, they were designed by a genius ...
more the preference for the style in which they do it and personal priorities. I certainly appreciate the ultra 3D of the best tube amps, but also the more top to bottom rendering of uber solid state.
there is room for both at the top of the heap.
at some point I will have a set of tube amps to be able to shift to answer the siren call of that perspective. my investment in the other way has limited my choice for that.
Berning and his products are phenomenal. He is a true innovator within this hobby that can go quite askew with pseudo-science. I've met and spoken to him at a few shows. He's quite humble and softs spoken.
I have owned one of his ZH-270's for about 10 years - I sold it last year to make some room for my direct drive amps for the Beveridge electrostatics. The 270 and all the Quadrature derivatives do bass like no other tube amp you have heard. Hartley describes the nature of Berning's amp well in his article. I have heard the 211/845 but not in my system.
Unfortunately, Berning went to intermediary distribution which turned end user cost about 2.5x what it was. The distributor and dealer get their princely cut. At $75K I wouldn't do it. At half of that it would be "reasonable".
I prefer the 211... not the 845 but then I roll Wyetech 211 into the system now and then and that's a beast so I'm biased to the 211. The Berning is a winner if your speakers and your budget manages it.
Those Wyetechs are very nicely made products! I reviewed the Wyetech Pearl preamp about 11 years ago and it was a very nice product.
Does yours use the Bartolucci output transformers? I know in the beginning Wyetech was using Audio Note output iron. Apparently, Wyetech amps do not sound particularly tubey but are very transparent and open with great bass.
Hello,
Yes, the Wyetech does fly under the radar. I believe if they used a traditional dealer/distribution channel they would be 2-3x price. Mine is the latest with the Bartlucci transformers. I can't hear the difference between the two as I had the original one on loan for some time before purchasing. This model is all power supply at over 45kg or about 110lbs.
Interesting. I have the Ayon Crossfire III and it is also 45Kg of mostly power supply (although the output transformers are also quite large). The Aries Cerat Diana, which I still have for review, is tipping the scales at 110Kg though...now that is a heavy amp!
