Do you have any acoustic measurements to substantiate such claims?
I don't do measurements. I trust my ears. Which claims?Do you have any acoustic measurements to substantiate such claims?
Did it myself. Not over damped at all. As I've said - best sound I've ever achieved.Wow, that must have taken the marketing guys a while to think up.
By the way, from your photos, your room looks way over damped (too much treatment). Did you have someone treat the room or do it yourself?
I'm not trying to be difficult, but this still reads like an explanation of diffusion. Diffusers scatter sound waves (which are necessarily transmitted by air in our listening environments) by bouncing air off of a corrugated surface. There are many different patterns that can be used to accomplish this effect, each of which change the frequencies that are influenced.Diffusors scatter the sound waves and have to be tailored and targeted to specific frequency ranges and room dimmensions. ZR Acoustics panels prevent reflected sound waves from forming ( at a molecular level according to DHDI) by bouncing the air off of many thousands of non-parallel surfaces per square foot of panel, and work at all frequencies.
Yes I am pretty sure low fr waves haven't read the theory and would just see a flat wall ... it seems primarily a diffuser for HF but it may have an interesting sideways dispersion and perhaps some cancelling nulls in that dispersion ( partcularly at centre of circles) that lowers reflections back to the listener without greatly reducing the "life" in the room. Its pretty hard to visualize what might happen in that circular pattern .. you see a few products like that but no one publishes dispersion patterns as far as I knowI'm not trying to be difficult, but this still reads like an explanation of diffusion. Diffusers scatter sound waves (which are necessarily transmitted by air in our listening environments) by bouncing air off of a corrugated surface. There are many different patterns that can be used to accomplish this effect, each of which change the frequencies that are influenced.
Perhaps this product has created a novel corrugated pattern that increases the effective frequency range?
The trade secret, what makes ZR Acoustics panels work as claimed is a precise, specific size, angle, and pattern of non-parallel surfaces. Hanson Hsu was granted U.S. Patent #9,845,598 for the original Zero Reflection panel design. The current circular one that they use (as in my photos) is an advancement on and superceded that original design.I'm not trying to be difficult, but this still reads like an explanation of diffusion. Diffusers scatter sound waves (which are necessarily transmitted by air in our listening environments) by bouncing air off of a corrugated surface. There are many different patterns that can be used to accomplish this effect, each of which change the frequencies that are influenced.
One thing to avoid at all costs is having the LP right up against the back wall.
Ideally yes but not always possible in a small room, and moving the listening seat a few feet from the rear wall doesn't make much difference. With the ZR Acoustics panels the best sound in my room is with the listening seat up against the rear wall/panels as in the "Creator Series" example at the DHDI website :One thing to avoid at all costs is having the LP right up against the back wall.
Always hate it when 'quantum anything' gets added to a products marketing, however I am not a scientist nor have I heard what these ZR panels do so no comment directed towards them. I am a little confused at the difference between 'zero reflection' and 'anechoic'...
I think the client lists speaks to the efficacy of the product: https://deltahdesign.com/portfolio/Those that are quoted in your post. One thing is telling us about your room, endorsing the manufacturer claims needs something to substantiate them.
Panel thickness/depth is irrelevant to the ZR technology since the panels don't absorb, diffuse, or trap. You can see in the comparison/price list what the thickness of the various panels is:Anyone have access to this journal via work?
I'm curious how thick they have to get to get down to 225hz.
Broadband fractal acoustic metamaterials for low-frequency sound attenuation: https://aip.scitation.org/doi/10.1063/1.4963347
but much uglier.Here's another product that also uses fractal patterns to accomplish broadband diffusion. I sat right up against the rear wall with a SD9F panel behind me @ Aaudio Imports when he was in Colorado and could not hear any reflected sound. It was very impressive.
https://www.goldenacoustics.com/productsLine.php
That panel goes down to 70Hz, but is quite a bit bigger than the ZR panels...
I love the sense of invention in our hobby and our commitment to sound above all things Cal… but this does rather look like Dolly Parton’s sound recording studio.Here's another product that also uses fractal patterns to accomplish broadband diffusion. I sat right up against the rear wall with a SD9F panel behind me @ Aaudio Imports when he was in Colorado and could not hear any reflected sound. It was very impressive.
That panel goes down to 70Hz, but is quite a bit bigger than the ZR panels... Depth: 9in, Length: 94in, Width: 34in, Weight: 150lbs.
So just what is the male equivalent of Waf… uhmmm may I suggest that the mother of pearl finish here in particular has rather low Maf… or is it Haf![]()
Dolly Parton?I don't know, it could double as a climbing wall![]()
You can see the logic in that one ... the relections are up and down from ear level and the diffuser depth at ear level could work at 70HzHere's another product that also uses fractal patterns to accomplish broadband diffusion. I sat right up against the rear wall with a SD9F panel behind me @ Aaudio Imports when he was in Colorado and could not hear any reflected sound. It was very impressive.
Different patterns for different frequencies...You can see the logic in that one ... the relections are up and down from ear level and the diffuser depth at ear level could work at 70Hz
Dont know what the patterns down each side do but at least the whole unit is non symmetric minimizing lobing between like dispersion patterns from each panel .. as you go higher and lower they reflect back into the room rather than up and down , avoiding ceiling relections back to listener
I see on their site they also have an option cover them with a stretch fabric ... even they understand they are butt ugly as Kal notes below!
